Compiling .pioenvs/reflow-oven-controller/FrameworkArduino/Esp-frag.cpp.o
/config/esphome/reflow-oven-controller.yaml: In lambda function:
/config/esphome/reflow-oven-controller.yaml:90:42: error: 'class esphome::slow_pwm::SlowPWMOutput' has no member named 'state'; did you mean 'float esphome::slow_pwm::SlowPWMOutput::state_'? (not accessible from this context)
90 | return {std::to_string(id(slow_pwm_h).state)};
In file included from src/esphome.h:55,
from src/main.cpp:3:
src/esphome/components/slow_pwm/slow_pwm_output.h:53:9: note: declared protected here
53 | float state_{0};
/config/esphome/reflow-oven-controller.yaml:90:48: error: could not convert '{<expression error>}' from '<brace-enclosed initializer list>' to 'esphome::optional<float>'
Compiling .pioenvs/reflow-oven-controller/FrameworkArduino/Esp-version.cpp.o
Archiving .pioenvs/reflow-oven-controller/libf5a/libSPI.a
Compiling .pioenvs/reflow-oven-controller/FrameworkArduino/Esp.cpp.o
*** [.pioenvs/reflow-oven-controller/src/main.cpp.o] Error 1
It doesn’t seem to allow it to be accessed like that. What component actually uses the output? If it is a light or a fan, the value of the output will be represented by a slider.
The component using it should have a way to display it’s value.
