I’ve made switches for my amplifier matrix that controls multiple speaker sets. 2 shown below.
What I didn’t know was possible is now reality with help from this forum (thank you!)
How can I create a call command to show the current state of each switch? The only way currently is to turn it off and on, and engage it with home assistant.
Turning this into a toggle switch would be nice too!
Thank you.
Since we’re here, and you helped me create those volume sliders, can you tell me how to turn them into typical volume sliders? Right now they’re truncated. Here’s my attempts
Dear Matt, I have an artsound receiver art54 with 4 zones and I’m also looking a long time to integrate this in home assistant as you did.
I have also a protocol for this receiver. i can send the PDF if you want.
Serial settings:
Art5.4 Main CPU Software Revision: 1.05
Use COM2 on Art5.4
Settings for serial port on control unit:
38400 baud, 8 databits, 1 stopbit, no par.
TCPIP Socket communication
ART 5.4 Main CPU version 1.06 or higher
IP (standard): 192.168.123.80 (may be modified)
Socket: 5017
When you want I can send htis PDF. In this protocol I read for ON or OFF in a zone :
Syntax:
*PWR,,RD;
Equivalent commands:
*ON,;
*OFF,;
Parameters
Zone | MAIN |
Example:
Client to server: *PWR, 1, ON; turns zone 1 on
Client to server: *PWR, 1, RD; reads power status
Server to client: *PWR, 1, ON; Zone 1 is on.
So When I change in your conf yaml <11PR00\r\n to *PWR, 1 ON; it can work you think?
But first I want to test command *PWR, 1, ON; with an app as you did. With app have you used?
Wich port do I have to use? I have on IP 192.168.1.23 three open ports :
