I try to display in a map (entity or other) some of the information contained in sub entity of this entity.
Of course I didn’t find anything…
Thank you for your help.
entity: switch.schedule_94325e
state: waiting
entries:
- 0DT0000T0200A0C01
- 0DT0200T0400A1C01
- 0DT0400T1000A2
- 0DT1000T1300A3C01
- 0DT1300T2359A3C01
actions:
- service: set_temperature
entity: climate.daikin
hvac_mode: heat
temperature: 21
hvac_mode: heat
temperature: 19
hvac_mode: heat
temperature: 18
hvac_mode: heat
temperature: 22
conditions:
- entity: input_boolean.thermostats_ac_on_off
match_type: is
state: 'on'
- entity: input_boolean.thermostats_away
match_type: is
state: 'off'
next_trigger: '2020-12-02T10:00:00+01:00'
friendly_name: AC Normal
icon: 'mdi:calendar-clock'
