I see the sensor inside of homekit but its under climate>temperature. I want to see it as a full Icon that I can see inside of one of the rooms. I have been searching the internet but having no luck with any of the configurations that I have tried.
esphome:
esp32:
board: nodemcu-32s
framework:
type: arduino
Enable logging
logger:
Enable Home Assistant API
api:
encryption:
key: “”
ota:
password: “”
wifi:
ssid: !secret iot-wifi_ssid
password: !secret iot-wifi_password
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: “Pooltemp1 Fallback Hotspot”
password: “023LkMp32Hl7”
captive_portal:
Setup Sensors
dallas:
- id: “dallas_sensor_pooltemp1”
pin: GPIO23
- platform: dallas
dallas_id: dallas_sensor_pooltemp1
device_class: temperature
address: 0xa2031720567eff28
filters:- lambda: return x * (9.0/5.0) + 32.0;
unit_of_measurement: “°F”
Any ideas on how to do that with the code provided or an example of how to get dallas temp data into homekit as a full size icon? All help is appreciated.
