I am trying to get both the display and an audio output via a MAX98357 to work on a WT32-SC01.
As long as the display is not configured, the audio output of an MP3 stream via i2s_audio and media_player works without problems.
Dropouts and noise can be heard when the display is enabled and updated.
For a tolerable output I have to set update_interval to several seconds.
For example, if I set update_interval: 5s, I hear the noise every 5s. It gets better when I set auto_clear_enabled to False. Probably because then less has to be written on the screen.
Also, the more I output on the screen, the bigger the problem becomes.
My guess is that the update of the display simply takes so long that the DMA(?) buffer for the audio output runs empty.
Any ideas? Known problem?
here are some parts with the hopefully relevant parts of the configfile:
# Blacklight
output:
- platform: ledc
pin: GPIO23
light:
- platform: monochromatic
output: gpio_23_backlight_pwm
name: "${friendly_name} Backlight"
restore_mode: RESTORE_DEFAULT_ON
# Display
spi:
clk_pin: GPIO14
mosi_pin: GPIO13
miso_pin: GPIO12
# 320x480
display:
- platform: ili9xxx
model: ST7796
cs_pin: GPIO15
dc_pin: GPIO21
reset_pin: GPIO22
rotation: 90
update_interval: 5s
auto_clear_enabled: False
lambda: |-
auto black = Color(0, 0, 0);
it.rectangle(0, 0, 150, 150);
it.rectangle(150, 0, 150, 150);
it.image(0, 0, id(imgplay));
it.image(150, 0, id(imgstop));
it.image(300, 150, id(imgminus));
it.image(300, 0, id(imgplus));
it.filled_rectangle(0, 320-30, 480, 320, black);
it.printf(0, 320-30, id(font20), "%d:%02d/%d:%02d %s", (int)(id(media_pos).state )/ 60, (int)(id(media_pos).state) % 60, (int)(id(media_len).state )/ 60, (int)(id(media_len).state) % 60,id(title).state.c_str());
# Touchscreen
external_components:
- source: github://gpambrozio/esphome@FT6336U-touch
components: [ ft63x6 ]
i2c:
sda: 18
scl: 19
scan: false
touchscreen:
- platform: ft63x6
i2c_id: i2c_bus_intern
on_touch:
- script.execute: backlight_script
# Audio
i2s_audio:
i2s_lrclk_pin: GPIO25
i2s_bclk_pin: GPIO26
media_player:
- platform: i2s_audio
name: ESPHome I2S Media Player
dac_type: external
i2s_dout_pin: GPIO32
mode: mono
