Hi All,
I want to display the weather from several different locations on a “Weather” View in the dashboard. I will probably use OpenWeatherMap, but want to move to Tomorrow.io when I can get an integration done. Anyway, what is the best way to accomplish this?
Here you go, two Open Weather location’s together…
Install the integration two time’s
and lovelace looks like this:
- type: weather-forecast
name: Het weer in Amsterdam
entity: weather.openweathermap
secondary_info_attribute: wind_bearing
entity: weather.openweathermap2
name: Het weer in Rybnicna
Thank you I will try that tonight.
This helped me too, thank you!
