Display which motion sensor triggered alarm in UI
Hi all,
I use several motion sensors to trigger the alarm component, but it’d be really useful to see which sensor triggered the alarm.
Anyone have any thought on how to do this?
looking for an automation to notify, or a sensor to show the last triggering sensor? Both are available :wink:
Have a look at Conditional Cards You could perhaps trigger on a group state and have a glance card displayed with all the sensors on it, one of which will be lit.
I have set up a glance card with all the sensors on it (not conditional), but this isn’t that useful as it is very much real-time data. It doesn’t actually tell me which motion sensor triggered the alarm.
So if the kitchen sensor activated the alarm, but after a few seconds there is no longer any motion in the kitchen, I wouldn’t know that this caused the alarm.
Is there a way to add a last activated to the item in the front end?
yes, I use @rogro82 's CC variable for that:
variable:
  last_motion:
    value: 'Not set'
    restore: true
    attributes:
      icon: mdi:map-marker
      friendly_name: 'Last Motion'
and automation:
automation:
# Update Last Motion variable
  - alias: 'Update Last Motion'
    id: 'Update Last Motion'
    initial_state: 'on'
      platform: state
      entity_id:
        - binary_sensor.laundry_motion_sensor
        - binary_sensor.dining_table_motion_sensor
        - etc
        - etc
      to: 'on'
      service: variable.set_variable
        variable: last_motion
        attributes_template: >
                "history_1": "{{ variable.state }}",
                "history_2": "{{ variable.attributes.history_1 }}",
                "history_3": "{{ variable.attributes.history_2 }}",
                "history_4": "{{ variable.attributes.history_3 }}",
                "history_5": "{{ variable.attributes.history_4 }}",
                "history_6": "{{ variable.attributes.history_5 }}",
                "history_7": "{{ variable.attributes.history_6 }}",
                "history_8": "{{ variable.attributes.history_7 }}",
                "history_9": "{{ variable.attributes.history_8 }}",
                "history_10": "{{ variable.attributes.history_9 }}"
      data_template:
        value: >
          {{ trigger.to_state.attributes.friendly_name|replace('motion sensor','') }}:
          {{as_timestamp(states.variable.last_motion.last_changed)| timestamp_custom('%X') }}
57
or in buttons (needs a few tricks…):
55
That’s pretty slick! When I get time I’ll have a look at implementing that.
For now my hacky solution is to add 'last_changed to the entity This at least gives me an idea of which sensors have been activated recently:
type: entities
theme: dark_theme
entities:
  - entity: binary_sensor.door_window_sensor_158d000288d283
    secondary_info: last-changed
yes, that is also useful, and I did that in my entities card, glance card doesn’t support that unfortunately. Buttons do !
03
Laundry is on but no motion, Dining is on and motion detected, the rest are Off :wink:
Do you use an automation for your alarm?
If so you could use the trigger of the automation to set a persistent notification with the friendly_name of the trigger.
yes, indeed a fine solution, for situations a motion trigger needs to set an alarm (away-mode)
might not be too fine a setup, getting pers. notifications all the time when simply moving around in the home… :wink:
  - alias: 'Motion sensor picked up motion'
    id: 'Motion sensor picked up motion'
    initial_state: off
      platform: state
      entity_id:
        - etc
      to: 'on'
    condition:
      - condition: template
        value_template: >
          {{ is_state('input_boolean.notify_motion', 'on')}}
        value_template: >
          {{ is_state('group.family', 'not_home')}}
      - service: notify.notify
        data_template:
          title: Motion sensor alert
          message: >
            {{ trigger.to_state.attributes.friendly_name }} picked up motion. Check what's up!
        value_template: >
          {{ is_state('input_boolean.notify_announcement', 'on')}}
      - service: notify.ios_telefoonmhb
        data_template:
          title: >
            {{ trigger.to_state.attributes.friendly_name }} alert:
          message: 'Sensor motion speech:'
            push:
              sound: 'US-EN-Morgan-Freeman-Motion-Detected.wav'
or add the pers. notify. service:
      value_template: >
        {{ is_state('input_boolean.persistent_notification_create', 'on')}}
    - service: persistent_notification.create
      data_template:
        message: >
note that I have this automation initial_state: off, and it is turned on on leaving the house, entering motion detection mode.
I love these cards, do you have the yaml that generated them ?
@Mariusthvdb and CC variable Wow! This solution is awesome…well worth spending the time to get this working.
Cheers!
Sure, but am away now, please remind me in a week or so? I’ll try to remember ?
Thanks, hopefully you can post when you get a chance
here you go:
type: vertical-stack
cards:
  - type: horizontal-stack
    cards:
      - type: custom:button-card
        template: horizontal-filler
      - type: 'custom:button-card'
        template: button_default_title
        styles:
          card:
            - color: '#555B65'
            - background-color: 'var(--paper-card-background-color)'
        state:
          - operator: template
            value: >
              return states['binary_sensor.motion_in_hq'].state === 'on';
              var id = states['variable.last_motion'].state;
              return 'Motion detected: ' + id.substr(0, id.length-11)
            styles:
              card:
                - color: red
                - background-color: '#555B65'
            value: >
              return states['binary_sensor.motion_sensors_active'].state === 'on'
            name: Motion sensors active
            styles:
              card:
                - color: green
            value: >
              return states['binary_sensor.motion_sensors_active'].state === 'off'
            name: Motion detection Off
    cards:
        template: button_motion
        entity: binary_sensor.laundry_motion_sensor
#        tap_action:
#          action: call-service
#          service: switch.toggle
#          service_data:
#            entity_id: >
#              [[[return 'switch.' + entity.entity_id.split('.')[1] + '_switch' ]]]
        entity: binary_sensor.dining_table_motion_sensor
        entity: binary_sensor.auditorium_motion_sensor
        entity: binary_sensor.frontdoor_motion_sensor
    cards:
        entity: binary_sensor.dorm_motion_sensor
#        tap_action:
#          service_data:
#            entity_id: switch.dorm_motion_sensor_switch
        entity: binary_sensor.corridor_motion_sensor
        entity: binary_sensor.master_bedroom_motion_sensor
        entity: binary_sensor.corridor_terrace_motion_sensor
    cards:
        entity: binary_sensor.corridor_office_motion_sensor
        entity: binary_sensor.control_room_motion_sensor
        entity: binary_sensor.attic_motion_sensor
        entity: binary_sensor.poort_buiten_motion_sensor
    cards:
        tap_action:
          action: more-info
#        name: 'Last Motion'
          var fakestate = `<span style="color: red;font-size: 11px;word-wrap:break-word;"> ${entity.state.substr(0, entity.state.length-11)} </span>`;
          return 'Last motion' + "<br>" + fakestate
        entity: variable.last_motion
        show_label: false
        show_state: false
        show_last_changed: true
        show_name: true
#        label_template: >
#          return entity.state.substr(0, entity.state.length-11) +
#          "<br>" + entity.last_changed
        state:
          - operator: default
            styles:
              card:
                - color: grey
#                - opacity: 0.8
              icon:
                - color: red
        tap_action:
          action: more-info
        entity: binary_sensor.master_bedroom_motion_sensor_timed
        tap_action:
          action: more-info
        entity: binary_sensor.poort_buiten_motion_sensor_timed
        template: button_body
        lock:
          enabled: true
          unlock: hold
          exemptions:
            - username: !secret button_unlock_name
        confirmation:
          text: >
            [[[ return `Are you sure you want to toggle ${entity.attributes.friendly_name}?` ]]]
        entity: group.philips_motion_sensor_switches
        styles:
          state:
            - color: >
                [[[ if (entity.state == 'on') return 'green';return grey;]]]
          label:
            - color: >
          name:
            - color: grey
          icon:
            - color: >
my button motion template is:
button_motion:
  tap_action:
    service_data:
      entity_id: >
  state:
    - value: 'on'
      styles:
        card:
          - color: red
        name:
          - color: black
        icon:
          - color: red
      value: >
        return entity.attributes.on == true
      styles:
        card:
          - color: grey
        icon:
          - color: 'green'
        state:
          - color: 'green'
    - operator: default
      styles:
        card:
          - color: grey
#          - opacity: 0.8
        icon:
          - color: grey
using template button_body:
button_body:
  color: auto
  aspect_ratio: 1/1
  show_state: true
  show_label: true
  tap_action:
    action: more-info
    haptic: light
  hold_action:
    action: more-info
    haptic: success
  styles:
    icon:
      - color: grey
    lock:
      - color: red
    card:
      - color: 'var(--primary-color)'
      - padding-left: 5px
    name:
      - text-overflow: unset
      - white-space: unset
      - word-break: break-word
      - text-align: start
      - justify-self: start
      - font-weight: bold
      - font-family: Helvetica
      - font-size: 13px
    label:
      - text-align: start
      - font-size: 11px
    state:
      - text-align: start
      - font-size: 11px
      - text-transform: capitalize
      - font-weight: bold
    grid:
      - grid-template-areas: '"i" "n" "s" "l"'
      - grid-template-columns: 1fr
      - grid-template-rows: 1fr min-content min-content
    img_cell:
      - justify-content: start
      - align-items: start
hope this helps :wink:
