Display Zoneminder Cameras stream on FireTv
I have Zoneminder setup and I can view all the cameras from the Home assistant Dashboard. I have the Alexa interfaced to the Home assistant working. I can play sounds, do TTS, etc. I can access the dashboard remotely.
Now, I’m trying to stream the cameras to the Amazon Fire Cube. I’m using the command Alexa, show the front door camera. I have setup the YAML file according to the following Amazon Alexa Smart Home Skill - Home Assistant
Alexa says, the front door doesn’t support that. I tried all my cameras, same thing.
Any suggestions? How to debug this?
Thanks for your help,
Kevin
