I’m trying to implement something similar to, what looks like a simple ‘status’ display which can be seen in the first post here:
I have created what I believe to be the relevant template sensor in my main config file in HA here:
- name: "Oil Status"
unit_of_measurement: ""
state: >
{% if states.sensor.oil_level.state == 999 %}
ERROR
{% elif states.sensor.oil_level.state | int > 75 %}
GOOD
{% elif states.sensor.oil_level.state | int > 50 %}
OK
{% elif states.sensor.oil_level.state | int > 25 %}
LOW
{% else %}
WARNING
{% endif %}
picture: >-
/local/cancel.png
/local/green.png
/local/yellow.png
/local/amber.png
{% else %}
/local/red.png
{% endif %}
Ideally I would like the relevant image to display in my Oil Tank ‘entities card’ on my dashboard, in place of either the icon, or the text state (LOW in this example)
Looking at the entities card documentation it doesn’t look like I can have a state determined picture in this card.
I’ve created a picture entity card separately, as a test, and this pulls the correct template sensor state and displays the correct image based on the current state - here is my code:
type: picture-entity
entity: sensor.oil_status
state_image:
GOOD: /local/images/green.png
OK: /local/images/yellow.png
LOW: /local/images/amber.png
WARNING: /local/images/red.png
This can be seen in the dashboard screenshot above. Can anyone suggest how I can get a (much smaller!) state based image to display in the way I am aiming for? I can’t see how the OP in the linked post has done this with his dashboard, but it looks like a glance card? I’ve tried creating a glance card, but can’t see a way of including a state based image - only the state text?
Appreciate any help!
