So lately I’m creating a bunch of automations, testing and sometimes I like to double-check and make sure they triggered correctly.
I am using the template below to see the automations trigged in the last 5 hours:
{% set mins = 360 %}
{%- for state in states.automation|sort(attribute='last') -%}
{% set last = as_timestamp(state.attributes.last_triggered) %}
{% set current = as_timestamp(now()) - (mins*60) %}
{%- if (last != None) and last > current -%}
{{state.entity_id}}:
last triggered: {{last|timestamp_custom("%H:%M") }}
{% endif %}
{%- endfor -%}
It results in something like this:
automation.someone_arrived:
last triggered: 12:57
automation.disarm_alarm:
automation.sunset_lights:
last triggered: 17:21
automation.announce_visitor:
last triggered: 16:40
automation.dark_mode:
last triggered: 18:20
What I’d like to see is the last 5 or 10 automations sorted by when they were triggered, with the newest entry on top.
Is there any sorting I can add to this template? Any add-on I should look for? A new automation?
Thanks in advance!
did you give auto-entities a try? it can sort based on attributes, and also use count https://github.com/thomasloven/lovelace-auto-entities#sorting-entities
you wouldn’t need a backend template at all
Thanks a lot! I installed auto-entities and already got it working just like I wanted, thanks for pointing the way!
In case anyone wants to do the same, after installing auto-entities I add the following custom card:
type: 'custom:auto-entities'
show_empty: false
card:
type: entities
title: Last five automations
show_header_toggle: false
filter:
include:
- domain: automation
options:
secondary_info: last-triggered
sort:
method: last_triggered
count: 5
I’ll just have to figure if I can turn off the toggle.
ever figure out how to turn off the toggles?
Hey, overtime I changed to using the logbook card which shows more details and no buttons. It’s quite similar:
card:
type: logbook
hours_to_show: 1
title: Histórico
filter:
include:
options:
- domain: script
options:
show_empty: false
type: custom:auto-entities
view_layout:
position: sidebar
