Displaying HA sensor on display
Hi I am trying to display a HA text senor on a display. I feel that i am close.
to start with, i implemented the display with text, that works then imported the HA sensor, that works. now i am trying to display the HA sensor on the screen, and i have wasted hours trying!
My code so far:
esphome:
esp8266:
  board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
ota:
  password: "de7c0b13c11a729f9eed8e7a1acaa951"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Display-1 Fallback Hotspot"
    password: "Pr9PxjSWZbhg"
captive_portal:
spi:
  clk_pin: D0
  mosi_pin: D1
display:
  - platform: max7219digit
    cs_pin: D8
    num_chips: 4
    lambda: |-
       it.print(0,0, id(digit_font), id(message).state);
#      it.strftime(0, 0, id(digit_font), "%H:%M", id(hass_time).now());
font:
  - file: "gfonts://Roboto"
time:
  - platform: homeassistant
text_sensor:
    entity_id: sensor.sensor_alarm_name
and when compiling it come up with this error:
Compiling /data/display-1/.pioenvs/display-1/src/main.cpp.o
/config/esphome/display-1.yaml: In lambda function:
/config/esphome/display-1.yaml:38:47: error: no matching function for call to 'esphome::max7219digit::MAX7219Component::print(int, int, esphome::display::Font*&, std::string&)'
   38 |        it.print(0,0, id(digit_font), id(message).state);
any help on how i get past this would be great.
Try
id (message).state.c_str()
Amazing, thank you.
