Hefford27
(Graham Hefford)
January 27, 2018, 5:27pm
1
I have just converted to Hassio, I have most of the old config from a Ubuntu install of Home Assistant, however my Sensor for Sunrise / Sunset times are note working any ideas ?
## Sensor Config for Next Sunrise Time Reformatting ##
sensors:
nextsunrise:
friendly_name: 'Next Sun Rise'
value_template: "{{ as_timestamp(states.sun.sun.attributes.next_rising) | timestamp_custom('%-H:%M') }}"
icon_template: mdi:weather-sunset-up
## Sensor Config for Next Sunset Time Reformatting ##
sensors:
nextsunset:
friendly_name: 'Next Sun Set'
value_template: "{{ as_timestamp(states.sun.sun.attributes.next_setting) | timestamp_custom('%-H:%M') }}"
icon_template: mdi:weather-sunset-down
Ok, you’re also calling platform template twice, so one (or both if you’re calling more elsewhere) are probably being overwritten. Remove the lines ‘platform template’ and ‘sensors’ from the second one.
Hefford27
(Graham Hefford)
January 27, 2018, 5:40pm
3
Hi yes, just doubled checked its in my configuration.yaml
Bugger, edited my last post instead of replying here, sorry, very tired
Hefford27
(Graham Hefford)
January 27, 2018, 5:52pm
5
@anon43302295 its cool, thanks for helping
sensors:
nextsunrise:
friendly_name: "Next Sun Rise"
nextsunset:
friendly_name: "Next Sun Set"
still not working lol … its odd it worked before moving to Hassio
Do you have any other template sensors in the same file?
Hefford27
(Graham Hefford)
January 27, 2018, 6:01pm
7
@anon43302295 Yeah just moved them into the same section, and restarted still there same, here is my sensors.yaml, im totally lost…
## Sensor Config for Weather Info - Weather Underground ##
- platform: wunderground
api_key: removed
monitored_conditions:
- temp_high_record_c
- temp_high_1d_c
- temp_c
- temp_low_1d_c
- temp_low_record_c
- precip_1d
- precip_1d_mm
- wind_kph
- wind_1d_kph
- UV
- alerts
- precip_today_metric
## Sensor Config for Weather Info - Darksky ##
- platform: darksky
api_key: Removed
forecast array:
- summary
- icon
- nearest_storm_distance
- precip_type
- precip_intensity
- precip_probability
- temperature
- apparent_temperature
- dew_point
- wind_speed
- cloud_cover
- wind_bearing
- humidity
- pressure
- visibility
- ozone
- minutely_summary
- hourly_summary
- daily_summary
- temperature_max
- temperature_min
- apparent_temperature_max
- apparent_temperature_min
- precip_intensity_max
- uv_index
units: uk2
## Sensor Config for DSL Speed Test every 3 Hours ##
- platform: speedtest
minute: 30
hour:
- 1
- 3
- 6
- 9
- 12
- 15
- 18
- 21
- ping
- download
- upload
## Sensor Config for Travel Time To / From Work ##
- platform: google_travel_time
name: Home to Work Journey Time
api_key: Removed
origin: zone.home
destination: removed
options:
units: imperial
name: Work to Home Journey Time
api_key: Removed
origin: Removed
destination: zone.home
options:
units: imperial
name: Work to Home Journey Time Live Status
api_key: removed
origin: removed
options:
units: imperial
## Sensor Config for Home Assistant Version ##
- platform: version
## Sensor Config for Evenironmental Seasons ##
- platform: season
type: astronomical
sensors:
nextsunrise:
nextsunset:
doorbell:
value_template: >-
{% if states.binary_sensor.door_window_sensor_158d0001a49988.state == 'on' %}
Not Ringing
{% elif states.binary_sensor.door_window_sensor_158d0001a49988.state == 'off' %}
Ringing
{% else %}
n/a
{% endif %}
sidegate:
value_template: >-
{% if states.binary_sensor.door_window_sensor_158d00019e0551.state == 'on' %}
off
{% elif states.binary_sensor.door_window_sensor_158d00019e0551.state == 'off' %}
on
{% else %}
n/a
{% endif %}
## Sensor Config for Home Assistant Uptime ##
- platform: uptime
## Sensor Config for Home Assistant Server Health ##
- platform: systemmonitor
resources:
- type: 'disk_use_percent'
arg: '/'
- type: 'disk_free'
arg: '/'
- type: memory_free
- type: load_1m
- type: load_5m
- type: load_15m
- type: processor_use
- type: last_boot
- type: since_last_boot
- type: memory_use_percent
## Sensor Config for Home Assistant Server CPU Speed ##
- platform: cpuspeed
## Sensor Config for ZoneMinder Events ##
- platform: zoneminder
Any errors in relation to the templates on startup? (Click the ‘i’ on the dev panel and look in the list.)
Hefford27
(Graham Hefford)
January 27, 2018, 6:32pm
9
Hi Mate, no just complains about port 80 for Google Home listening Port.
Do the other sensors in the file work?
Hefford27
(Graham Hefford)
January 27, 2018, 6:36pm
11
Yeah i have all the weather stuff and my state conversions for 2 door sensors I have modded are working fine … just the Sunset and Sunset … hence my confusion lol
What happens when you put the template in the jinja panel? (little black icon that looks like a piece of paper with <> on)
Hefford27
(Graham Hefford)
January 27, 2018, 6:44pm
13
Nothing returns…
Weird as it worked on the non Hassio Version of HA
Hefford27
(Graham Hefford)
January 27, 2018, 6:47pm
14
its something hassio does not like about timestamp_custom(’%-H:%M’) part of the code.
When I remove it it returns a long date/time value i think it is
Can’t help you there, I don’t understand that part myself, but at least we’ve narrowed down the cause and hopefully someone else will be able to get that bit fixed up for you
Hefford27
(Graham Hefford)
January 27, 2018, 6:52pm
16
Thanks for all your help appreciate it
Hefford27
(Graham Hefford)
January 27, 2018, 7:00pm
17
Just fixed it lol, never used the Ninja Page before.
Hassio does not like the - in the code timestamp_custom(’%-H:%M’).
Removed that and now it works, sorry and thanks for you help again…
Hefford27:
Ninja Page
That would be soooooooooooooo much cooler
Glad you got sorted
