Hi.
I’ve built a small display to show info from my Solar inverter. I also have a battery and I’m trying to create a simple filter to show an up or down arrow if the battery is charging or discharging.
I’m using a 20x4 LCD screen and can display the static symbols but I can’t figure out how show them from a filter.
- platform: homeassistant
entity_id: sensor.battery_charge
name: "Solar panel power"
entity_id: sensor.growatt_pv_active_power
entity_id: sensor.growatt_power_phase_a
entity_id: sensor.load
name: "Battery Charging Power"
entity_id: sensor.battery_charging_power
display:
- platform: lcd_gpio
dimensions: 20x4
data_pins:
- D0
- D1
- D2
- D3
enable_pin: D4
rs_pin: D5
user_characters:
- position: 1
- 0b00000
- 0b00000
- 0b00000
- 0b00000
- 0b00000
- 0b10001
- 0b01010
- 0b00100
- position: 2
- 0b00100
- 0b00100
- 0b00100
- 0b00100
- 0b00100
- 0b11111
- 0b01110
- 0b00100
lambda: |-
it.printf(0, 0, "Solar Battery %.0f%%", id(solar_battery).state);
it.printf(0, 1, "Solar Power %.0fW", id(solar_power).state);
it.printf(0, 2, "Grid Load %.2fkW", id(grid_load).state);
it.printf(0, 3, "Inverter Load %.0fW", id(inverter_load).state);
on_value_range:
if:
condition:
sensor.in_range:
- above: 50.0
then:
- lambda: |-
it.printf(19, 0, "\x5E");
# - number:
# platform: template
# id : battery_charging.state
# on_value_range:
# above: 50
# below: 3500
# lambda: |-
# it.printf(19, 0, "\x5E");
# it.printf(19, 0, "\x5E"); # up arrow
# it.printf(19, 1, "\x01"); # down arrow
# it.printf(19, 3, "\x02"); # big down arrow
# it.strftime(15, 2, "%H:%M", id(my_time).now());
I’ve tried “on_value_range” under lambda but I get errors when compiling. “it.printf(19, 0, “\x5E”);” should print an up arrow in the top right digit when charging power is above 50 watts.
Any help appreciated. I’m probably doing this completely wrong, I’ve been round the docs but I’m no further forward.
