Displaying Temperature in Celsius Only for Specific Entities
I prefer to use imperial system for environment temperature sensors and HVAC thermostat. However when monitoring temperatures for computer components (CPU, HDD, enclosure, etc.) I prefer to read them in Celsius. The command itself to get CPU temperature is in Celsius but HA is too smart to convert it into Fahrenheit for me.
I have "unit_system": "imperial" in my core.config, and have my CPU temperature entity created as follows:
  - platform: command_line
    name: Nanopi CPU Temperature
    command: cat /sys/class/thermal/thermal_zone0/temp
    unit_of_measurement: '°C'
    value_template: '{{value | multiply(0.001) | round(1) }}'
and the display card looks like:
      - type: 'custom:mini-graph-card'
        entities:
          - sensor.nanopi_cpu_temperature
        line_color: red
        line_width: 8
        hours_to_show: 4
        points_per_hour: 12
How do I force CPU Temp displayed in Celsius?
did you ever figure this out? i’m running into the same issue.
Was there ever a solution found?
I am trying to figure just the opposite - having all temperatures in Celsius but wanting my hot tub in Fahrenheit.
I’m starting to think I’ll have to manually implement the whole functionality of a thermostat, but in manually controlled and converted values.
It makes no sense.
Home assistant doesn’t seem to understand that people don’t use just one system for everything… :man_shrugging:t3:
While I cannot seem to be able to do it for a thermostat (wonder why)
I can changes preferences for entities of the type sensor.
In there, display unit is selectionnable to Fahrenheit, Celsius and Kelvin.
Right now I’ve placed my system in imperial - it turns my thermostat to Fahrenheit. Then I configured weather and sensors to Celsius. Gives me what I need.
Hopefully this may help others.
What do you mean by “smart to convert it into Fahrenheit”?
The sensor gets a value in Celsius, and it is supposed to be displayed in Lovelace w/o any conversion with UoM=“Celsius”.
