I just started with configuring and now I have a very beginner question:
I have an external python script (whose function is maybe subject to be transferred into HomeAssistant later)
which has some Measurement values, e.g. a Temperature.
Now I want to use the remote api to transfer the Temperature into Home Assistant and Display it there.
Maybe I just have to use remote.set_state(api, ‘sensor.temperature’, new_state=123)
But I don’t know which kind of object in home assistant I have to create, in order to just display a value.
I played around with the some sensors, especially the platform template, but had no success so far.
Can somebody give me a short hint in the right direction?
so from an existing, different python script into home assistant.
This script controls some hardware and has it’s own timing.
In this particular case, I want homeassistant as slave.
What I am searching for is an Item which can be displayed (like a sensor) and whose value I can set via the remote api.
With the command_line I could probably go over a file, but that’s not what I would prefer.
I tried a little bit further,
Actually I just called:
remote.set_state(api, ‘sensor.office_temperature’, new_state=temp)
from my outside script, and a new Item is appearing in Home assistant, showing my Temperature.
