I’m looking for a way to distribute esphome firmware compilation against multiple hosts. I’m known that is possible for C/C++ code (eg. with distccd), but their is a way with esphome ?
Thanks !
Thanks !
Really? It’s not a big job. Hardly worth the bother.
When you host esphome on a RPI and you have more than 20 devices, compile a new firmware for each of them could take more than one hour of CPU time. I think I could clearly reduce this time by distributed the compilation with my laptop’s CPU more than 10 times powerful than an RPI4’s CPU! So, no, I think my question is legit.
Install esphome on the more powerful machine then.
Yes I do see the problem on a pi. Perhaps a search for distributed compilation on platformio would reveal results.
I’m curious if a solution was ever found for this
No, I moved my ESPhome installation on a powerful host and I stopped to handle all upgrades. I also writed a python script to trigger all devices upgrades: I run it in a screen terminal. If you found a solution, I’m still interested!
I was also looking into this to be honest (this Thread popped up quite high in Google Search ).
I guess that, if distcc or similar is NOT possible, then I’d setup an automatic builder VM using esphome compile
and put the resulting Firmware (and configuration etc) on a Shared Network Folder.
Then, instead of running esphome run
I’ll just do esphome upload
on another (with USB connected ESP32 Device), assuming that will work without re-triggering a compile.
