So as some of you may have experienced before, the MyQ integration just stopped updating and the gateway went offline for the sixth time this month. Rather than continue to troubleshoot it, I decided to find a permanent, less headache inducing and cloudless alternative. But I can not use a regular dry contact due to the fact that my garage lift unit utilizes the Security 2.0+ protocol for commands. Im not going to make a comment on how I feel about it because thats not the purpose of this.
After spotting a solution on Garadget, I decided to deploy a solution. Please note that past this point, your mileage will vary. Apparently, some lift units/wall controls do not allow two wall switches at once. My lifts thankfully do allow more than one, but dont assume yours will. I would double check. Anyway, the button I ordered looks like this,
Its a simple switch that outputs the Security 2.0 protocol.
What must be done now, is a wifi dry contact relay of choice needs to actuate a button press on this particular switch. I chose a Shelly 1 because its relatively simple to set up, small and I generally like Shelly products. If you choose a Shelly 1, youll want to set it as a dry contact relay switch and switch it to 12v DC power. Youll obviously need a 12v power supply for this, but note that 1 amp is more than plenty of power.
The Shelly relay will then be connected to soldered leads on the switch, as shown here:
Youll also need a reed switch to declare the state of the garage door. Now this part is tricky, because every lift is different. For example, this house was renovated before we moved in, so the doors are lifted by a rubber belt, rather than a metal chain. Rob from “The Hookup” has an excellent video on this very project but my implementation will reverse the reed switch state. One of the things I noticed when I first deployed this was the fact that the door could be ajar and still show as closed, which is obviously a downside. To fix that, I mounted the reed switch to the other side of the belt, so the magnet makes contact when the door is closed. If not its not near the switch, the door will show as open. How reliable this will be is yet to be determined but for now it works. Shown here.
I say this because the arm “knuckle” as it moves on the rail gets really close to the magnet and seems to brush it or dislodge it, so Ill have to monitor that. While it was on the otherside, it didnt have that problem. As I said before, your mileage may vary.
SInce I just deployed this, I am monitoring for any issues, but what I can tell you, it hasnt gone offline once, unlike MyQ
