Chacsam
(Frédéric)
October 24, 2021, 6:34am
1
I am trying to get rid of a divide by Zero error, but it’s still there.
Basically I want to calculate the ratio of consumed solar energy. At night production is 0, so that’s a given.
My code is:
value_template: "{{ (((states('sensor.daily_solar_production')|float(0) -states('sensor.daily_electricity_export_total')|float(0)) / states('sensor.daily_solar_production')|float(1))*100) | round(2) }}"
availability_template: "{{ 0 not in [states('sensor.daily_solar_production')|int]}}"
In the modelling tool, it returns “False” as availability so that should work.
Yet I still get error messages in the log
TemplateError('ZeroDivisionError: float division by zero') while processing template 'Template("{{ (((states('sensor.daily_solar_production')|float(0) -states('sensor.daily_electricity_export_total')|float(0)) / states('sensor.daily_solar_production')|float(1))*100) | round(2) }}")' for attribute '_attr_native_value' in entity 'sensor.daily_auto_conso_solar'
What can I do to solve that?
Using a If…Then could work but isn’t that clean is it?
tom_l
October 24, 2021, 7:56am
2
Yes testing for 0 is the way to do it.
value_template: "{{ none if states('sensor.daily_solar_production')|float(0) == 0 else (((states('sensor.daily_solar_production')|float(0) - states('sensor.daily_electricity_export_total')|float(0)) / states('sensor.daily_solar_production')|float(1))*100) | round(2) }}"
availability_template: "{{ states('sensor.daily_solar_production')|float(0) != 0}}"
koying
(Chris B)
October 24, 2021, 8:10am
3
Now, Frédéric has a point that the template shouldn’t even be rendered if its availability is False, functionaly-wise…
Whatever is using the template sensor should check that before rendering the sensor.
Frédéric, what is “using” the sensor? Is it only for display or is something else using it?
tom_l
October 24, 2021, 8:37am
4
Try this without the changes to the value template:
availability_template: "{{ not is_state('sensor.daily_solar_production', '0') }}"
Chacsam
(Frédéric)
October 24, 2021, 9:12am
5
Hi, thanks for your feedback,
@koying ,
Today this sensor is indeed only used for display, but I don’t exclude that I might use it for some automation (notification or whatever else) in the future.
@tom_l
I don’t think my availability_sensor is the issue, I have tried various versions and still have the same issue: even though the sensor shouldn’t be available, HA calculates it and thereby divides by 0.
koying
(Chris B)
October 24, 2021, 9:18am
6
And does it properly display as “unavailable”?
Chacsam
(Frédéric)
October 26, 2021, 4:06pm
8
So, to avoid “divide by zero” errors I have to do that?
value_template: >-
{% if is_state('sensor.hourly_solar_production', '0.0') %}
{{ ('0' | float) }}
{% else %}
{{ (((states('sensor.hourly_solar_production')|float(0) -states('sensor.hourly_electricity_export_total')|float(0)) / states('sensor.hourly_solar_production')|float(1))*100) | round(2) }}
{% endif %}
123
(Taras)
October 26, 2021, 4:16pm
9
If you wish, you can reduce it by using a variable and an inline if statement:
value_template: >-
{% set hsp = states('sensor.hourly_solar_production')|float(0) %}
{{ 0 if hsp == 0 else (((hsp - states('sensor.hourly_electricity_export_total')|float(0)) / hsp) * 100)|round(2) }}
(Taras)
October 26, 2021, 9:00pm
10
FYI
I thought you might be interested in this very recent PR:
home-assistant:dev
← home-assistant:async_track_template_result_master_template
opened 02:42PM - 26 Oct 21 UTC
You are amazing! Thanks for contributing to our project!
Please, DO N… OT DELETE ANY TEXT from this template! (unless instructed).
## Proposed change
Describe the big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
Allow specifying a master template for `async_track_template_result`
The driver is to use this for template entities to block rendering of other templates when the availability template does not render as `True`
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [x] New feature (which adds functionality to an existing integration)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #
- This PR is related to issue:
- Link to documentation pull request:
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [ ] The code change is tested and works locally.
- [ ] Local tests pass. **Your PR cannot be merged unless tests pass**
- [ ] There is no commented out code in this PR.
- [ ] I have followed the [development checklist][dev-checklist]
- [ ] The code has been formatted using Black (`black --fast homeassistant tests`)
- [ ] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [ ] Untested files have been added to `.coveragerc`.
The integration reached or maintains the following [Integration Quality Scale][quality-scale]:
The Integration Quality Scale scores an integration on the code quality
and user experience. Each level of the quality scale consists of a list
of requirements. We highly recommend getting your integration scored!
- [ ] No score or internal
- [ ] 🥈 Silver
- [ ] 🥇 Gold
- [ ] 🏆 Platinum
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/en/development_checklist.html
[manifest-docs]: https://developers.home-assistant.io/docs/en/creating_integration_manifest.html
[quality-scale]: https://developers.home-assistant.io/docs/en/next/integration_quality_scale_index.html
[docs-repository]: https://github.com/home-assistant/home-assistant.io
If I understand it correctly, it intends to implement new behavior where if the availability_template
evaluates to false
, it will block rendering of other templates in the entity (i.e. its state
/value_template
