Hi all,
at the moment I am facing an issue with a division by zero in my logs.
The sensor which is causing the division by zero is “maxdiskspace” - and the value will be received from a NodeRed flow.
I do know that the sensor template itself is working, because I do get a correct value displayed - I asume, that the division by zero just happens after a restart of HomeAssistant - when the NodeRed flow was not yet triggered.
I’ve tried to prevent the division by zero with an IF / ELSE statement - but it seems not working as expected - and I can’t see why… ?!
Can you please have a look at my template and let me know, where I might have done a mistake?
Logger: homeassistant.components.template.template_entity
Source: components/template/template_entity.py:72
Integration: Template (documentation, issues)
First occurred: 14:20:12 (5 occurrences)
Last logged: 14:20:12
TemplateError('ZeroDivisionError: float division by zero') while processing template 'Template("{% if is_state('sensor.lxc_01_maxdisksize', '0') or is_state('sensor.lxc_01_diskusage', '0') %} 0.0 {% else %} {% set maxdiskspace = states('sensor.lxc_01_maxdisksize') | float %} {% set useddiskspace = states('sensor.lxc_01_diskusage') | float %} {{ (( useddiskspace / maxdiskspace) | float * 100) | round(2) }} {% endif %}")' for attribute '_attr_native_value' in entity 'sensor.samba_used_disk_space_percentage'
and this is the template, causing the error:
# Proxmox Monitoring Calc-Free Disk-Space
samba_used_disk_space_percentage:
friendly_name: 'LXC-01 used Disk space %'
value_template: >
0.0
{% else %}
{% endif %}
unit_of_measurement: '%'
availability_template: "{{ states('sensor.lxc_01_maxdisksize') not in ['0', 'unavailable', 'unknown', 'none'] }}"
