I’m working on a DIY alarm panel project to integrate with Home Assistant, based on an ESP32 running ESPHome firmware. The system has 8 zones and includes a tamper detection feature that triggers if a sensor is manipulated or a wire is cut—pretty handy for catching any foul play.
It connects via Ethernet, has a 12V output for a siren, and is designed to be expandable. I’m planning to design an add-on PCB that allows for 8 more PIR motion detectors. In total, I want to support up to 30 opto-isolated digital inputs for things like door/window sensors, smoke detectors, etc. I might even throw in a few relay outputs just in case.
While not directly related, I’m also thinking of adding support for 8 irrigation zones, since it wouldn’t take much extra effort and could make use of some of the spare outputs.
This is still a work in progress and more of an experimental build to meet my own needs. But if anyone has ideas to improve it—or thinks it could be useful for their own setup—feel free to share suggestions!
