I have an VW e-UP.
I use dexters-web.de and this seems to work…I havnt got around yet to connec the OVMS to the CAN3 (Climate) som atm i cant control anything. Only read from the CAN
change <Char_ID>, <User_Name> andtoken acordanly to your needs
- platform: rest
scan_interval: 60
resource: https://ovms.dexters-web.de:6869/api/status/<Car_ID>?username=<User_Name>&password=<Token>
value_template: "{{ value_json.soc }}"
json_attributes:
- alarmsounding
- batt_capacity
- batt_current
- batt_range_speed
- bt_open
- cac100
- carawake
- carlocked
- caron
- charge_kwh_grid
- charge_kwh_grid_total
- charge_timestamp
- chargepowerinput
- chargerefficiency
- chargestate
- charging
- charging_12v
- cooldown_active
- cp_dooropen
- estimatedrange
- fl_dooropen
- fr_dooropen
- handbrake
- idealrange
- idealrange_max
- m_msgage_d
- m_msgage_s
- m_msgtime_d
- m_msgtime_s
- mode
- odometer
- parkingtimer
- pilotpresent
- soc
- soh
- staleambient
- staletemps
- temperature_ambient
- temperature_battery
- temperature_cabin
- temperature_charger
- temperature_motor
- temperature_pem
- units
- vehicle12v
- vehicle12v_current
- vehicle12v_ref
- platform: rest
scan_interval: 60
resource: https://ovms.dexters-web.de:6869/api/location/<Car_ID>?username=<User_Name>&password=<Token>
value_template: "{{ value_json.longitude }},{{ value_json.latitude }}"
json_attributes:
- altitude
- direction
- drivemode
- energyrecd
- energyused
- gpslock
- latitude
- longitude
- m_msgage_l
- m_msgtime_l
- power
- speed
- stalegps
- tripmeter
- platform: rest
scan_interval: 30
resource: https://ovms.dexters-web.de:6869/api/charge/<Car_ID>?username=<User_Name>&password=<Token>
value_template: "{{ value_json.chargestate }}"
json_attributes:
- batt_current
- batt_range_speed
- battvoltage
- cac100
- carawake
- caron
- charge_estimate
- charge_etr_full
- charge_etr_limit
- charge_etr_range
- charge_etr_soc
- charge_kwh_grid
- charge_limit_range
- charge_limit_soc
- charge_timestamp
- chargeb4
- chargecurrent
- chargeduration
- chargekwh
- chargelimit
- chargepower
- chargepowerinput
- chargerefficiency
- chargestarttime
- chargestate
- chargesubstate
- chargetimermode
- chargetimerstale
- chargetype
- charging
- charging_12v
- cooldown_active
- cooldown_tbattery
- cooldown_timelimit
- cp_dooropen
- estimatedrange
- idealrange
- idealrange_max
- linevoltage
- m_msgage_d
- m_msgage_s
- m_msgtime_d
- m_msgtime_s
- mode
- pilotpresent
- soc
- soh
- staleambient
- staletemps
- temperature_cabin
- temperature_motor
- temperature_pem
- units
- vehicle12v
- vehicle12v_ref
sensors:
car_alarmsounding:
value_template: "{{ states.sensor.car_status.attributes.alarmsounding }}"
icon_template: "mdi:alarm"
car_batt_capacity:
value_template: "{{ states.sensor.car_status.attributes.batt_capacity }}"
device_class: "battery"
icon_template: "mdi:battery"
car_batt_current:
value_template: "{{ states.sensor.car_status.attributes.batt_current }}"
device_class: "current"
icon_template: "mdi:current-dc"
car_batt_range_speed:
value_template: "{{ states.sensor.car_status.attributes.batt_range_speed }}"
device_class: "speed"
icon_template: "mdi:speedometer"
car_bt_open:
value_template: "{{ states.sensor.car_status.attributes.bt_open }}"
icon_template: "mdi:car-door"
car_cac100:
value_template: "{{ states.sensor.car_status.attributes.cac100 }}"
car_carawake:
value_template: "{{ states.sensor.car_status.attributes.carawake }}"
icon_template: "mdi:car-connected"
car_carlocked:
value_template: "{{ states.sensor.car_status.attributes.carlocked }}"
icon_template: "mdi:lock"
car_caron:
value_template: "{{ states.sensor.car_status.attributes.caron }}"
device_class: "power"
icon_template: "mdi:power"
car_charge_kwh_grid:
value_template: "{{ states.sensor.car_status.attributes.charge_kwh_grid }}"
device_class: "energy"
icon_template: "mdi:flash"
car_charge_kwh_grid_total:
value_template: "{{ states.sensor.car_status.attributes.charge_kwh_grid_total }}"
car_charge_timestamp:
value_template: "{{ states.sensor.car_status.attributes.charge_timestamp }}"
device_class: "timestamp"
icon_template: "mdi:clock"
car_chargepowerinput:
value_template: "{{ states.sensor.car_status.attributes.chargepowerinput }}"
car_chargerefficiency:
value_template: "{{ states.sensor.car_status.attributes.chargerefficiency }}"
car_chargestate:
value_template: "{{ states.sensor.car_status.attributes.chargestate }}"
car_charging:
value_template: "{{ states.sensor.car_status.attributes.charging }}"
car_charging_12v:
value_template: "{{ states.sensor.car_status.attributes.charging_12v }}"
car_cooldown_active:
value_template: "{{ states.sensor.car_status.attributes.cooldown_active }}"
icon_template: "mdi:fan"
car_cp_dooropen:
value_template: "{{ states.sensor.car_status.attributes.cp_dooropen }}"
car_estimatedrange:
value_template: "{{ states.sensor.car_status.attributes.estimatedrange }}"
device_class: "distance"
icon_template: "mdi:map-marker-distance"
car_fl_dooropen:
value_template: "{{ states.sensor.car_status.attributes.fl_dooropen }}"
car_fr_dooropen:
value_template: "{{ states.sensor.car_status.attributes.fr_dooropen }}"
car_handbrake:
value_template: "{{ states.sensor.car_status.attributes.handbrake }}"
icon_template: "mdi:car-brake-parking"
car_idealrange:
value_template: "{{ states.sensor.car_status.attributes.idealrange }}"
car_idealrange_max:
value_template: "{{ states.sensor.car_status.attributes.idealrange_max }}"
car_m_msgage_d:
value_template: "{{ states.sensor.car_status.attributes.m_msgage_d }}"
car_m_msgage_s:
value_template: "{{ states.sensor.car_status.attributes.m_msgage_s }}"
car_m_msgtime_d:
value_template: "{{ states.sensor.car_status.attributes.m_msgtime_d }}"
car_m_msgtime_s:
value_template: "{{ states.sensor.car_status.attributes.m_msgtime_s }}"
car_mode:
value_template: "{{ states.sensor.car_status.attributes.mode }}"
icon_template: "mdi:car"
car_odometer:
value_template: "{{ states.sensor.car_status.attributes.odometer }}"
car_parkingtimer:
value_template: "{{ states.sensor.car_status.attributes.parkingtimer }}"
device_class: "duration"
icon_template: "mdi:timer"
car_pilotpresent:
value_template: "{{ states.sensor.car_status.attributes.pilotpresent }}"
icon_template: "mdi:account"
car_altitude:
value_template: "{{ states.sensor.car_location.attributes.altitude }}"
icon_template: "mdi:altimeter"
car_direction:
value_template: "{{ states.sensor.car_location.attributes.direction }}"
icon_template: "mdi:compass"
car_drivemode:
value_template: "{{ states.sensor.car_location.attributes.drivemode }}"
car_energyrecd:
value_template: "{{ states.sensor.car_location.attributes.energyrecd }}"
car_energyused:
value_template: "{{ states.sensor.car_location.attributes.energyused }}"
car_gpslock:
value_template: "{{ states.sensor.car_location.attributes.gpslock }}"
car_latitude:
value_template: "{{ states.sensor.car_location.attributes.latitude }}"
icon_template: "mdi:map-marker"
car_longitude:
value_template: "{{ states.sensor.car_location.attributes.longitude }}"
car_m_msgage_l:
value_template: "{{ states.sensor.car_location.attributes.m_msgage_l }}"
car_m_msgtime_l:
value_template: "{{ states.sensor.car_location.attributes.m_msgtime_l }}"
car_power:
value_template: "{{ states.sensor.car_location.attributes.power }}"
car_speed:
value_template: "{{ states.sensor.car_location.attributes.speed }}"
car_stalegps:
value_template: "{{ states.sensor.car_location.attributes.stalegps }}"
icon_template: "mdi:map-marker-off"
car_tripmeter:
value_template: "{{ states.sensor.car_location.attributes.tripmeter }}"
car_batt_current:
value_template: "{{ states.sensor.car_charge.attributes.batt_current }}"
value_template: "{{ states.sensor.car_charge.attributes.batt_range_speed }}"
car_battvoltage:
value_template: "{{ states.sensor.car_charge.attributes.battvoltage }}"
device_class: "voltage"
car_cac100:
value_template: "{{ states.sensor.car_charge.attributes.cac100 }}"
car_carawake:
value_template: "{{ states.sensor.car_charge.attributes.carawake }}"
car_caron:
value_template: "{{ states.sensor.car_charge.attributes.caron }}"
car_charge_estimate:
value_template: "{{ states.sensor.car_charge.attributes.charge_estimate }}"
car_charge_etr_full:
value_template: "{{ states.sensor.car_charge.attributes.charge_etr_full }}"
car_charge_etr_limit:
value_template: "{{ states.sensor.car_charge.attributes.charge_etr_limit }}"
car_charge_etr_range:
value_template: "{{ states.sensor.car_charge.attributes.charge_etr_range }}"
car_charge_etr_soc:
value_template: "{{ states.sensor.car_charge.attributes.charge_etr_soc }}"
value_template: "{{ states.sensor.car_charge.attributes.charge_kwh_grid }}"
value_template: "{{ states.sensor.car_charge.attributes.charge_kwh_grid_total }}"
car_charge_limit_range:
value_template: "{{ states.sensor.car_charge.attributes.charge_limit_range }}"
car_charge_limit_soc:
value_template: "{{ states.sensor.car_charge.attributes.charge_limit_soc }}"
value_template: "{{ states.sensor.car_charge.attributes.charge_timestamp }}"
car_chargeb4:
value_template: "{{ states.sensor.car_charge.attributes.chargeb4 }}"
car_chargecurrent:
value_template: "{{ states.sensor.car_charge.attributes.chargecurrent }}"
car_chargeduration:
value_template: "{{ states.sensor.car_charge.attributes.chargeduration }}"
car_chargekwh:
value_template: "{{ states.sensor.car_charge.attributes.chargekwh }}"
car_chargelimit:
value_template: "{{ states.sensor.car_charge.attributes.chargelimit }}"
car_chargepower:
value_template: "{{ states.sensor.car_charge.attributes.chargepower }}"
value_template: "{{ states.sensor.car_charge.attributes.chargepowerinput }}"
value_template: "{{ states.sensor.car_charge.attributes.chargerefficiency }}"
car_chargestarttime:
value_template: "{{ states.sensor.car_charge.attributes.chargestarttime }}"
car_chargestate:
value_template: "{{ states.sensor.car_charge.attributes.chargestate }}"
car_chargesubstate:
value_template: "{{ states.sensor.car_charge.attributes.chargesubstate }}"
car_chargetimermode:
value_template: "{{ states.sensor.car_charge.attributes.chargetimermode }}"
car_chargetimerstale:
value_template: "{{ states.sensor.car_charge.attributes.chargetimerstale }}"
car_chargetype:
value_template: "{{ states.sensor.car_charge.attributes.chargetype }}"
car_charging:
value_template: "{{ states.sensor.car_charge.attributes.charging }}"
car_charging_12v:
value_template: "{{ states.sensor.car_charge.attributes.charging_12v }}"
value_template: "{{ states.sensor.car_charge.attributes.cooldown_active }}"
car_cooldown_tbattery:
value_template: "{{ states.sensor.car_charge.attributes.cooldown_tbattery }}"
car_cooldown_timelimit:
value_template: "{{ states.sensor.car_charge.attributes.cooldown_timelimit }}"
car_cp_dooropen:
value_template: "{{ states.sensor.car_charge.attributes.cp_dooropen }}"
car_estimatedrange:
value_template: "{{ states.sensor.car_charge.attributes.estimatedrange }}"
car_idealrange:
value_template: "{{ states.sensor.car_charge.attributes.idealrange }}"
car_idealrange_max:
value_template: "{{ states.sensor.car_charge.attributes.idealrange_max }}"
car_linevoltage:
value_template: "{{ states.sensor.car_charge.attributes.linevoltage }}"
car_m_msgage_d:
value_template: "{{ states.sensor.car_charge.attributes.m_msgage_d }}"
car_m_msgage_s:
value_template: "{{ states.sensor.car_charge.attributes.m_msgage_s }}"
car_m_msgtime_d:
value_template: "{{ states.sensor.car_charge.attributes.m_msgtime_d }}"
car_m_msgtime_s:
value_template: "{{ states.sensor.car_charge.attributes.m_msgtime_s }}"
car_mode:
value_template: "{{ states.sensor.car_charge.attributes.mode }}"
car_pilotpresent:
value_template: "{{ states.sensor.car_charge.attributes.pilotpresent }}"
car_soc:
value_template: "{{ states.sensor.car_charge.attributes.soc }}"
car_soh:
value_template: "{{ states.sensor.car_charge.attributes.soh }}"
car_staleambient:
value_template: "{{ states.sensor.car_charge.attributes.staleambient }}"
icon_template: "mdi:thermometer-off"
car_staletemps:
value_template: "{{ states.sensor.car_charge.attributes.staletemps }}"
car_temperature_ambient:
value_template: "{{ states.sensor.car_charge.attributes.temperature_ambient }}"
device_class: "temperature"
icon_template: "mdi:thermometer"
car_temperature_battery:
value_template: "{{ states.sensor.car_charge.attributes.temperature_battery }}"
car_temperature_cabin:
value_template: "{{ states.sensor.car_charge.attributes.temperature_cabin }}"
car_temperature_charger:
value_template: "{{ states.sensor.car_charge.attributes.temperature_charger }}"
car_temperature_motor:
value_template: "{{ states.sensor.car_charge.attributes.temperature_motor }}"
car_temperature_pem:
value_template: "{{ states.sensor.car_charge.attributes.temperature_pem }}"
car_units:
value_template: "{{ states.sensor.car_charge.attributes.units }}"
icon_template: "mdi:ruler"
car_vehicle12v:
value_template: "{{ states.sensor.car_charge.attributes.vehicle12v }}"
car_vehicle12v_current:
value_template: "{{ states.sensor.car_charge.attributes.vehicle12v_current }}"
car_vehicle12v_ref:
value_template: "{{ states.sensor.car_charge.attributes.vehicle12v_ref }}"
