Cool
just seen that.
Or the other way around? Enter pin first using S1-S4 and then choose S5 - Arm Away, S6 - Arm Home, S7 Disarm?
I have an RFID reader (RFID-RC522) on a NodeMCU that send the RFID tag of a user to HASS over MQTT to set the users presence to “Home” maybe this board could be implemented too to add a quick method to arm or disarm the alarm?
I stole the code from somewhere, can’t remember where but it was originally designed for an alarm system, has lots of code in it relating to alarms but I only use the topic “”/rfid/user" to trigger automations.
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <SPI.h>
#include “MFRC522.h”
/* wiring the MFRC522 to ESP8266 (ESP-12)
RST = GPIO4
SDA(SS) = GPIO2
MOSI = GPIO13
MISO = GPIO12
SCK = GPIO14
GND = GND
3.3V = 3.3V
#define RST_PIN 4 // RST-PIN GPIO4
#define SS_PIN 2 // SDA-PIN GPIO2
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
// Wifi Connection details
const char ssid = “”;
const char* password = “”;
// MQTT Server address
const char* mqtt_server = “”;
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
void setup() {
Serial.begin(9600);
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
// Connect to Wifi
void setup_wifi() {
pinMode(5, OUTPUT); // Red LED
pinMode(5, HIGH);
pinMode(0, OUTPUT); // Greem :LED
pinMode(0, HIGH);
delay(2);
// We start by connecting to a WiFi network
Serial.println();
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(“.”);
Serial.println(“”);
Serial.println(“WiFi connected”);
Serial.println(“IP address: “);
Serial.println(WiFi.localIP());
// Check for incoming messages
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print(“Message arrived [”);
Serial.print(topic);
Serial.print(”] “);
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
// Alarm is on
if ((char)payload[1] == ‘n’) {
Serial.println();
Serial.print(“Alarm is on”);
Serial.println();
on_red_led();
// Alarm is off
if ((char)payload[1] == ‘f’) {
Serial.println();
Serial.print(“Alarm is off”);
Serial.println();
on_green_led();
// Alarm is arming
if ((char)payload[2] == ‘m’) {
Serial.println();
Serial.print(“Alarm is arming”);
Serial.println();
flash_red_led();
// Alarm is disarming
if ((char)payload[2] == ‘s’) {
Serial.println();
Serial.print(“Alarm is disarming”);
Serial.println();
flash_green_led();
// Error
if ((char)payload[3] == ‘o’) {
Serial.println();
Serial.print(“Error wrong token”);
Serial.println();
blink_red_led();
// Reconnect to wifi if connection lost
void reconnect() {
// Loop until we’re reconnected
while (!client.connected()) {
Serial.print(“Attempting MQTT connection…”);
// Attempt to connect
if (client.connect(“ESP8266Client”, “username”, “password”)) {
Serial.println(“connected”);
// Once connected, publish an announcement…
client.publish(”/rfid/state”, “connected”);
// … and resubscribe
client.subscribe(“/alarm/state”);
} else {
Serial.print(“failed, rc=”);
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
// Main functions
void loop() {
if (!client.connected()) {
reconnect();
client.loop();
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent()) {
delay(50);
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial()) {
delay(50);
return;
// Show some details of the PICC (that is: the tag/card)
Serial.print(F(“Card UID:”));
dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
Serial.println();
// Send data to MQTT
String rfidUid = “”;
for (byte i = 0; i < mfrc522.uid.size; i++) {
rfidUid += String(mfrc522.uid.uidByte[i] < 0x10 ? “0” : “”);
rfidUid += String(mfrc522.uid.uidByte[i], HEX);
const char* id = rfidUid.c_str();
client.publish(“/rfid/user”, id);
delay(500);
client.publish(“/rfid/user”, “blank”);
delay(500);
// LED Loop
void blink_red_led(){
Serial.println(“Blinking Red”);
digitalWrite(0, LOW);
// Flash 10 times:
for(int i = 0; i < 9; i++)
digitalWrite(5, HIGH);
delay(200);
void flash_green_led(){
Serial.println(“Flashing Green LED”);
digitalWrite(5, LOW);
// Flash 15 times:
for(int i = 0; i < 14; i++)
digitalWrite(0, HIGH);
delay(1000);
delay(500);
void flash_red_led(){
Serial.println(“Flashing Red LED”);
// Flash 20 times:
for(int i = 0; i < 19; i++)
delay(1000);
delay(500);
void on_green_led(){
Serial.println(“Turning on green led”);
void on_red_led(){
Serial.println(“Turning on red led”);
// Helper routine to dump a byte array as hex values to Serial
void dump_byte_array(byte *buffer, byte bufferSize) {
for (byte i = 0; i < bufferSize; i++) {
Serial.print(buffer[i] < 0x10 ? " 0" : " ");
Serial.print(buffer[i], HEX);
