DIY Wi-Fi RGB LED Strip keeps on after turning off with HA
Hello everyone.
Currently I am trying to convert my cheap IR RGB controller to ESP based one. After all this process it actually works really good, I can apply every automation, put effect on it. My main problem is after clicking turning off button on HA, it keeps on with very slightly blue-white light. Is that about bad transistor that driven by the PWM output?
When I switch off from HA, it keeps slightly blue.
Thats my ESPHome code,
light:
 - platform: rgb
   red: hue1
   green: hue2
   blue: hue3
   effects:
      # Use default parameters:
      - random:
      # Customize parameters
      - random:
          name: "Slow Random Effect"
          transition_length: 30s
          update_interval: 30s
      - random:
          name: "Fast Random Effect"
          transition_length: 4s
          update_interval: 5s
      - strobe:
      - strobe:
          name: Strobe Effect With Custom Values
          colors:
            - state: True
              brightness: 100%
              red: 100%
              green: 90%
              blue: 0%
              duration: 500ms
            - state: False
              duration: 250ms
            - state: True
              brightness: 100%
              red: 0%
              green: 100%
              blue: 0%
              duration: 500ms
      - flicker:
      - flicker:
          name: Flicker Effect With Custom Values
          alpha: 95%
          intensity: 1.5%
      - lambda:
          name: My Custom Effect
          update_interval: 1s
          lambda: |-
            static int state = 0;
            auto call = id(rgbtvvv).turn_on();
            // Transtion of 1000ms = 1s
            call.set_transition_length(1000);
            if (state == 0) {
              call.set_rgb(1.0, 1.0, 1.0);
            } else if (state == 1) {
              call.set_rgb(1.0, 0.0, 1.0);
            } else if (state == 2) {
              call.set_rgb(0.0, 0.0, 1.0);
            } else {
              call.set_rgb(1.0, 0.0, 0.0);
            call.perform();
            state += 1;
            if (state == 4)
              state = 0;
output:
 - platform: esp8266_pwm
   pin: 13
   frequency: 100 Hz
   max_power: 100%
   pin: 12
   frequency: 100 Hz
   max_power: 100%
   pin: 14
   frequency: 100 Hz
   max_power: 100%
That is my circuit,
I built new 3.3v supply for ESP12e. GPIO12-13-14 used as sPWM
As you can see it works and I can control it with HA.
