What am I doing wrong that I have sensors as control and not as sensor?
Hi! Can I use the power adapter with 18650 battery with 3.7V to use this device?
Hola Hola , tengo conectado solo un ds18b20 , el problema es que latemperatura no se renueva autoaticamente , para que haga una nueva lectura tengo que quitarle la luz y volver a darsela ,
alguien le ha pasado lo mismo ???
Same question here. How to get a “normal” temperature value?
