Hi guys, I’d need 2 Zigbee devices with 2 Buttons each, since some suitables devices are quite expensive i’ve chosen to look for a DIY solution. I searched the internet for some infos and i think i got the infos for making them but, since i’m not expert in DIY Zigbee I’d ask for your help.
Here is what i found:
I use PTVO firmware configuration to make the firmware for the module in a way like this:
These are the infos i gathered on the web after some days of searching. But since I’m a newbie I don’t know if that would be the right way or if it will work.
Search for flashing zigbee2mqtt firmware to cc2531 usb stick - there are many options, including just a raspberry pi without any additional hardware. Flashing 2530 modules is exactly the same, you just use PTVO custom firmware. I used exactly this touch button with cc2530 and it works. Keep in mind, free version of this firmware is not well suited for battery operation, you need to buy a license for power management. And it doesn’t work well with ZHA, you need to use zigbee2mqtt.
