remove the two comments, or fix the indentation like in the original post. I suspect they cause an error
#If you have issues with the history sensor doubling after restarting HA, add the line below (@BigG)
#availability: "{{ (states('sensor.rain_sensor_flips') not in ('unknown', 'unavailable')) }}"
Yes, I removed the two comments and now Rainfall Today is 0.4 in.
I suspect at this point, the weekly, monthly and annual all should read the same value.
They are reading Unknown. That’s an assignment for me to figure out.
@ekainz Unfortunately, I have to write again. Everything works except for the rain intensity. It always only shows me 0.00mm/h. But I can’t find the error. When I put it in the developer tools, it tells me ‘trigger’ is undefined.
Is this just a formatting issue? I just can’t get to the error and hope someone can help me
Hello, with the help of a friend, I was able to make the rain gauge soldering to work. Now this is working in HA.
However I noticed, an issue. When rain is very weak, let say 1 mm drop in 30 minutes, the rain gauge does not count anything. I noticed the drops remain on the device and don’t fall into the hole. Have you also noticed it ? And did you find a workaround ?
