I recently replayed my thermostat with an OpenTherm Thermostat 2 https://diyless.com/product/opentherm-thermostat2. Manually controlling the thermostat via MQTT works as expected.
I have an automation set in the morning which should then start heating the house. As far as I can see the automation fires, the thermostat recieves the target temperature
and after that the target temperature gets ignored it for x amount of time.
The image shows current temperature, heating and target temperature. To my understanding this is MQTT data from the OpenTherm Thermostat, so this is data from the device.
I want the heating to start when the target temperature is set and is much higher than the current temperature. I want no delay.
What can I do to fix this?
