HI all,
perhaps someone can help me out here. I am trying to connect a Busch Jäger Inet radio via DLNA renderer to home assistant. I can connect the radio to BubbleUPNP this work perfectly, but in HomeAssistant it connects and disconnects from the device every 3 seconds. I assume that the event handler is not passed correctly, but I have no idea how to proceed. Can someone help me out here?
Attached is the debug Log which shows the disconnect:
2023-02-06 00:23:17.860 DEBUG (MainThread) [homeassistant.components.dlna_dmr] Connecting to device at http://192.168.10.9:80/upnp/device.xml
2023-02-06 00:23:17.998 DEBUG (MainThread) [homeassistant.components.dlna_dmr] Getting event handler for EventListenAddr(host='192.168.10.1', port=0, callback_url=None)
2023-02-06 00:23:18.003 DEBUG (MainThread) [homeassistant.components.dlna_dmr] Started event handler at http://192.168.10.1:36911/notify
2023-02-06 00:23:18.084 DEBUG (MainThread) [async_upnp_client.profiles.dlna] Got no value for PresetNameList
2023-02-06 00:23:18.086 DEBUG (MainThread) [async_upnp_client.profiles.dlna] Got no value for Volume
2023-02-06 00:23:18.109 DEBUG (MainThread) [async_upnp_client.profiles.dlna] Got no value for PresetNameList
2023-02-06 00:23:18.110 DEBUG (MainThread) [async_upnp_client.profiles.dlna] Got no value for Volume
2023-02-06 00:23:18.136 DEBUG (MainThread) [homeassistant.components.dlna_dmr] Device unavailable: UpnpCommunicationError("ClientPayloadError('Response payload is not completed')", None)
2023-02-06 00:23:18.138 DEBUG (MainThread) [homeassistant.components.dlna_dmr] Disconnecting from RADIO_BAD
2023-02-06 00:23:27.861 DEBUG (MainThread) [homeassistant.components.dlna_dmr] Connecting to device at http://192.168.10.9:80/upnp/device.xml
2023-02-06 00:23:27.999 DEBUG (MainThread) [homeassistant.components.dlna_dmr] Getting event handler for EventListenAddr(host='192.168.10.1', port=0, callback_url=None)
2023-02-06 00:23:28.002 DEBUG (MainThread) [homeassistant.components.dlna_dmr] Started event handler at http://192.168.10.1:33773/notify
2023-02-06 00:23:28.087 DEBUG (MainThread) [async_upnp_client.profiles.dlna] Got no value for PresetNameList
2023-02-06 00:23:28.088 DEBUG (MainThread) [async_upnp_client.profiles.dlna] Got no value for Volume
2023-02-06 00:23:28.112 DEBUG (MainThread) [async_upnp_client.profiles.dlna] Got no value for PresetNameList
2023-02-06 00:23:28.113 DEBUG (MainThread) [async_upnp_client.profiles.dlna] Got no value for Volume
2023-02-06 00:23:28.138 DEBUG (MainThread) [homeassistant.components.dlna_dmr] Device unavailable: UpnpCommunicationError("ClientPayloadError('Response payload is not completed')", None)
2023-02-06 00:23:28.139 DEBUG (MainThread) [homeassistant.components.dlna_dmr] Disconnecting from RADIO_BAD
2023-02-06 00:23:37.862 DEBUG (MainThread) [homeassistant.components.dlna_dmr] Connecting to device at http://192.168.10.9:80/upnp/device.xml
2023-02-06 00:23:38.009 DEBUG (MainThread) [homeassistant.components.dlna_dmr] Getting event handler for EventListenAddr(host='192.168.10.1', port=0, callback_url=None)
Further I copied in the XML files of the radio:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<root xmlns="urn:schemas-upnp-org:device-1-0">
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<URLBase>http://192.168.10.9:80</URLBase>
<device>
<deviceType>urn:schemas-upnp-org:device:MediaRenderer:1</deviceType>
<friendlyName>RADIO_BAD</friendlyName>
<manufacturer>Busch-Jaeger</manufacturer>
<manufacturerURL>http://www.busch-jaeger.de</manufacturerURL>
<modelName>Radio iNet</modelName>
<modelDescription>Busch-Jaeger Internet Radio 8216U</modelDescription>
<modelNumber>Version 1</modelNumber>
<modelURL>http://www.busch-jaeger.de/de/audiovideo/radio-inet.htm</modelURL>
<serialNumber>78C40E4258E2</serialNumber>
<UDN>uuid:82168216-0000-0000-0000-XXXXXXXXXX</UDN>
<serviceList>
<service>
<serviceType>urn:schemas-upnp-org:service:RenderingControl:1</serviceType>
<serviceId>urn:upnp-org:serviceId:RenderingControl</serviceId>
<SCPDURL>/upnp/rencon.xml</SCPDURL>
<controlURL>/upnp/control/rencon</controlURL>
<eventSubURL>/upnp/event/rencon</eventSubURL>
</service>
<service>
<serviceType>urn:schemas-upnp-org:service:ConnectionManager:1</serviceType>
<serviceId>urn:upnp-org:serviceId:ConnectionManager</serviceId>
<SCPDURL>/upnp/conman.xml</SCPDURL>
<controlURL>/upnp/control/conman</controlURL>
<eventSubURL>/upnp/event/conman</eventSubURL>
</service>
<service>
<serviceType>urn:schemas-upnp-org:service:AVTransport:1</serviceType>
<serviceId>urn:upnp-org:serviceId:AVTransport</serviceId>
<SCPDURL>/upnp/avtrans.xml</SCPDURL>
<controlURL>/upnp/control/avtrans</controlURL>
<eventSubURL>/upnp/event/avtrans</eventSubURL>
</service>
</serviceList>
<presentationURL>http://192.168.10.9:80/index.shtml</presentationURL>
</device>
</root>
Can anyone help?
Thanks in advance
