I there any away to browse the contents of DLNA/UPNP devices and choose what to play in a media_player?
Sorry to reference a competitive solution, but homegenie has a component to do that http://www.homegenie.it/docs/upnp.php. I’m asking, if it is possible to do the same with Home-assistant.
Is it possible to have an iframe with a webpage for the media_player web UI? This way, you could integrate already made web UI for that media_player in a home-assistant card.
@vswraith,
Regarding automatic start the tv show in an automation rule. If you are using Kodi and the newly added tv shows are in a specific playlist, you might use the shell_command component to call a script with the following code:
