Switch colors brightness… all works but LED then goes to off state ha reports still on. Using other software (not HA) works perfect. The only settings that seems to effect it is “refresh every: 1” makes them flash on/off every second. Default of 0 results in off state after a second.
This is my config
light:
- platform: artnet_led
host: 10.1.10.38 # IP of Art-Net Node
max_fps: 25 # Max 40 per second
refresh_every: 1 # Resend values if no fades are running every x seconds, 0 disables automatic refresh
node_type: artnet-controller # Which protocol to use
universes: # Support for multiple universes
1: # Nr of Universe (see configuration of your Art-Net Node)
send_partial_universe: False # Only send the universe which contains data
output_correction: quadruple
#quadratic # optional: output correction for the whole universe, will be used as default if nothing is set for the channel
devices:
- channel: 6
type: rgbw
transition: 0
channel_size: 8bit
channel_setup: rgbwd
- channel: 11
type: rgbw
transition: 0
channel_size: 8bit
- channel: 16
type: rgbw
transition: 0
channel_size: 8bit
- channel: 21
type: rgbw
transition: 0
channel_size: 8bit
- channel: 26
type: rgbw
transition: 0
channel_size: 8bit
- channel: 31
type: rgbw
transition: 0
channel_size: 8bit
logger:
logs:
custom_components.artnet_led: debug
