It was a one time thing. I rebooted several times without issues. Now, I installed 2022.9.1 and all entities got disabled. I see this in the logs:
Logger: homeassistant.config
Source: custom_components/artnet_led/light.py:7
Integration: artnet_led (documentation)
First occurred: 11:50:25 (1 occurrences)
Last logged: 11:50:25
Platform error: light
File "/usr/src/homeassistant/homeassistant/config.py", line 878, in async_process_component_config
platform = p_integration.get_platform(domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 681, in get_platform
cache[full_name] = self._import_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 698, in _import_platform
return importlib.import_module(f"{self.pkg_path}.{platform_name}")
File "/usr/local/lib/python3.10/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
File "<frozen importlib._bootstrap>", line 1006, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 883, in exec_module
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
File "/config/custom_components/artnet_led/light.py", line 7, in <module>
from homeassistant.components.light import (
ImportError: cannot import name 'ATTR_WHITE_VALUE' from 'homeassistant.components.light' (/usr/src/homeassistant/homeassistant/components/light/__init__.py)
https://developers.home-assistant.io/blog/2022/08/18/light_white_value_removed/
EDIT: I see itâs fixed on github. I installed using HACS. Maybe itâs not picking up the new version?
EDIT: HACS is messing up I think:
This shows the correct repository is added.
In the custom_components folder however, I get this:
This is not the manifest that is on github.
EDIT: removed it and re-added. I think somehow there was an issue because both integrations have domain name artnet_led. Problem solved!
