DNS issues hass.io containers
I’m having problems with dns resolving from within homeassistant.
Tried almost everything I’ve found online, creating docker defaults, reinstalling hass.io etc.
The problem I’m facing is the home assistant container isn’t able to resolve dns requests.
When I change the name server in /etc/resolv.conf to let’s say, google DNS everything is working fine.
However after a reboot or restart DNS isn’t working anymore. This results in not working push messages, no external components can be loaded in node-red etc. I don’t use any dns plugins.
After a reboot my home assistant container:
nslookup: can't resolve '(null)': Name does not resolve
cnslookup: can't resolve 'nu.nl': Try again
bash-4.4# cat /etc/resolv.conf
nameserver 172.30.32.2
options ndots:0
Where 172.30.32.2 is my hass.io supervisor.
nameserver 127.0.0.11
options ndots:0
bash-4.4# nslookup klm.nl
Address 1: 193.57.244.90
So at first it’s not able to resolve, however after a second or three its resolving.
The bass.io supervisor acts as a DNS relay if I understand correctly.
If anyone can point me into the right direction so I can fix this shit permanently I would be very happy :slight_smile:
For the time being I execute a shell command on home-assistant start like echo name server 8.8.8.8 > /etc/resolv.conf but that’s not the way it’s supposed to work.
Are you using Ubuntu? Which one?
i have the same problem.
my hass.io container has the ip: 172.30.32.2
and its nameserver is the127.0.0.11
nslookup are working only an external names
in the home-assistant container i have the resolver 172.30.32.2 (aka hass.io container) and here no name lookup ist working.
i think it would be the easiest solution to set my routersgateway as the resolver von all container, but i dont know how.
Please help.
Greetings
Did anyone ever found a fix for this issue? I have the exact same issue as the thread starter. I use Ubunu 18.04LTS which has Docker version 18.06.1-ce, build e68fc7a.
If the supervisor is functioning as an DNS forwarder I would expect to see a listener on port 53 which I don’t.
Can someone tell how DNS resolution is meant to work on hassio?
Thanks.
I’m using hassOS on my raspberry pi and it seems to be using socat for DNS port forwarding on port 53 - hope this helps
The problem of resolving only external domains and internal domains but not the internal ones just specifying the domain (ex. ping host1 will not work but ping host1.local.domain will) is due to the use of Alpine Linux as base image for the containers. Alpine does not use GNU libc but musl libc and the second one doesn’t support the search directive of the resolv.con* file.
Here the link to the bug that will not be solved* because it was rejected: https://bugs.alpinelinux.org/issues/3977
My advice is to move away from alpine linux and move to a Debian or a CentOS base image, a little bit more “heavy” but more complete for sure.
I’ll try to build up an hass.io image based on different image but I don’t know if I’ve time.
Hope this help out.
I am having the same issue. I am running DNSmasq on the HASSio box if that makes a difference as it would be running on port 53. I am not exactly sure how the dockers work. I noticed the internal network but not sure how to make changes to them. Would I have to set the DNS on all containers?
Whenever I have DNSmasq or Pi-hole add-on running my homeassistant container can’t resolve DNS. Other containers can resolve and other devices on my network can use HA to resolve. As soon as I stop the DNS add-on that I have on at the time the homeassistant container can resolve again.
Same issue here. Running Hassio in Docker on Ubuntu 18.04. Local DNS resolves from my OpenWRT router for the base Ubuntu and other systems on my network. Avahi/Bonjour is not used. Hassio addons are unable to resolve local addresses but do resolve internet addresses.
I managed to brute force a fix for this issue by making a cronjob that runs every minute or so and executes this command docker exec -d homeassistant bash -c "echo 'nameserver 192.168.1.1' > /etc/resolv.conf"
This way everything seems to work, except for some components that require DNS on startup and dont have any retries if they fail to init, like Pushbullet integration. I guess it could be solved by changing DNS not in homeassistant but in “hassio_supervisor” container which homeassistant is supposedly looks at for DNS resolution
In no way elegant solution, but works.
EDIT:
Unfortunately I can’t seem to edit resolv.conf inside hassio_supervisor
bash-4.4# echo "nameserver 192.168.1.17" > /etc/resolv.conf
bash: /etc/resolv.conf: Permission denied
To you all still having this issue, easiest fix is adding your DNS config to the docker daemon. Then, every container created on that host will have the correct DNS already on start up.
https://l-lin.github.io/post/2018-09-03-docker_ubuntu_18_dns/
Did not work for me. Though I did not recreate the container. I tried to reinstall hassio and managed to fk up the whole system by running the simple apt-get install -y apparmor-utils apt-transport-https avahi-daemon ca-certificates curl dbus jq network-manager socat software-properties-common command. I don’t know how, but it removed lots of packages and failed to complete the installation with an error and… well, os is down.
Maybe this can help?
