Do automation actions run in sequence or parallel by default?
Hello, I have a pretty basic automation that happens when my alarm is triggered.
      # Set max volume on 3 devices (nest minis)
      - action: media_player.volume_set
        metadata: {}
          volume_level: 1
          device_id:
            - 123
            - 234
            - 345
      # Play my burglar alarm mp3 on each device
      - action: media_player.play_media
          entity_id: media_player.123
          media_content_id: media-source://media_source/local/audio/burglar-alarm.mp3
          media_content_type: audio/mpeg
        metadata:
          title: burglar-alarm.mp3
          thumbnail: null
          media_class: music
          children_media_class: null
          navigateIds:
            - media_content_type: app
            - media_content_type: ""
          entity_id: media_player.234
        metadata:
          thumbnail: null
          media_class: music
          navigateIds:
          entity_id: media_player.345
        metadata:
          thumbnail: null
          media_class: music
          navigateIds:
I have the actions in order of when I want them to happen so that the volume is maxed out first and then the MP3 plays.
What I notice happening every time is that the audio will play first and then the volume gets turned up. I’m not sure if it’s a weird nest quirk or if it’s something I can change in my automation. Has anyone else experienced this before? Any help would be greatly appreciated, thank you!
Hello shadow1349,
In that case, they are started in series, but don’t wait for it to complete because the speaker doesn’t feed that back, so add a delay between.
As @Sir_Goodenough mentioned, they run in series, however it’s important to note that some actions, although processed in series, may have asynchronous pieces to them, and an action may return as “completed” before the end result is actually reflected.
I had that exact issue dealing with media players myself, trying to reset volumes after playing audio. I had assumed that when I told it to play audio, that immediately following that the state would be playing - but the call to play audio is asynchronous, so it would process the request and go on to the next step in my automation before audio had begun playing.
If you find it feels like it’s racing, put a condition check between your steps (you can use a wait template with a timeout) so it waits for whatever it needs before it continues to the next action.
BTW, I’ll put this script here just in case it’s of use to you…
alias: Play media
icon: mdi:speaker-wireless
fields:
  speaker:
    selector:
      media: {}
    required: true
  volume:
    selector:
      number:
        min: 0
        max: 1
        step: 0.1
    default: 0.5
    required: false
sequence:
  - alias: Generate unique ID
    variables:
      scene_id: pm_{{ slugify(this.context.id) }}
  - alias: Ensure media player is ready
    if:
      - alias: If media player is not on
        condition: template
        value_template: "{{ is_state(speaker.entity_id, ['off', 'unavailable']) }}"
    then:
      - alias: Turn on media player
        action: media_player.turn_on
          entity_id: "{{ speaker.entity_id }}"
  - alias: Save media player state
    action: scene.create
      scene_id: "{{ scene_id }}"
      snapshot_entities: "{{ speaker.entity_id }}"
  - alias: Set volume
      volume_level: "{{ volume | default(0.5) }}"
    continue_on_error: true
  - alias: Play media
      announce: true
      media_content_id: "{{ speaker.media_content_id }}"
      media_content_type: "{{ speaker.media_content_type }}"
  - alias: Wait for media player to finish playing media
    sequence:
      - alias: Wait for media to start playing
        wait_template: "{{ is_state(speaker.entity_id, 'playing') }}"
        continue_on_timeout: true
        timeout: "00:00:15"
      - alias: Wait for media to finish playing
        wait_template: "{{ is_state(speaker.entity_id, 'idle') }}"
        timeout: "00:00:30"
  - alias: Restore media player state
    action: scene.turn_on
      entity_id: scene.{{ scene_id }}
  - alias: Garbage collection
    action: scene.delete
mode: parallel
Ah ok, that makes sense. Thank you!
