Do I have to double this trigger?
I have this automatisation
alias: Tussentijdse inschakeling bij thuiskomst
description: ‘’
  • platform: state
    entity_id: input_boolean.toggle_christian_is_thuis
    to: ‘on’
    condition:
  • condition: state
    entity_id: input_boolean.toggle_airco_living
    state: ‘on’
  • service: script.switch_airco_living_20_graden
    mode: single
For the same trigger I have to do this
condition:
  • condition: state
    entity_id: input_boolean.toggle_airco_gang
    state: ‘on’
  • service: script.switch_airco_gang
Can this been done in one automatisation ?
One option is to use two choose actions:
description: ''
  - platform: state
    to: 'on'
condition: []
  - choose:
    - conditions:
      - condition: state
        state: 'on'
      sequence:
        - service: script.switch_airco_living_20_graden
    default: []
  - choose:
    - conditions:
      - condition: state
        state: 'on'
      sequence:
        - service: script.switch_airco_gang
    default: []
mode: single
Nice, but I get an error
Message malformed: expected dictionary @ data[‘action’][0][‘choose’][0][‘sequence’][0]
description: ‘’
  • platform: state
    to: ‘on’
    condition: []
  • choose:
    • conditions:
      • condition: state
        state: ‘on’
        sequence:
        • script.switch_airco_living_20_graden
          default: []
  • choose:
    • conditions:
      • condition: state
        state: ‘on’
        sequence:
          default: []
          mode: single
Found it…service was gone.
Thanks, will test this tomorrow !
Just for testing I changed it to switch on some lights.
Unfortunately it doesn’t work…nothing happens (no lights).
Normally, both lights (switch.sfeerverlichting_links and switch.sfeerverlichting_rechts) should been on because input_boolean.toggle_airco_living and input_boolean.toggle_airco_gang are on.
description: ‘’
  - platform: state
    to: ‘on’
condition: []
  - choose:
      - conditions:
          - condition: state
            state: ‘on’
        sequence:
          - type: turn_on
            device_id: daec5c6545b70ab1e2a1aa4954463ce6
            entity_id: switch.sfeerverlichting_links
            domain: switch
    default: []
  - choose:
      - conditions:
          - condition: state
            state: ‘on’
        sequence:
          - type: turn_on
            device_id: dd77e7fcd8e29c8129905d5b77f148d9
            entity_id: switch.sfeerverlichting_rechts
            domain: switch
    default: []
mode: single
Double check your quotation marks… it looks like some of them have gotten switched to fancy quotes at some point in the copying and pasting.
You have very good eyes, better than me…
Thank you very much !
