Do I loose past statistics when I remove entities from the energy dashboard?
Mostly due to heavy experimentation, my energy tracking entities constantly changed. For example, I might switch integrations, merge energy monitoring for multiple circuits, re-configure ESPhome device which results in renamed entities etc. Now I see something like this:
Those devices have a “bookmark” icon in the dashboard config instead of a bolt:
Now when I select “Yearly” in the energy dashboard I can still see statistics of, say, the meanwhile non-existent circuit_2:
If I go on “Today” all of these old entities are still listed but zero.
I would REALLY like to clean this up and remove old entities from the energy dashboard config. However, I do not want to loose old statistics.
What happens if I remove these entities from the energy dashboard? Will I loose statistics? If yes, is there any workaround?
No, long-term statistics are currently retained indefinitely in your DB, unlike sensor states, etc. that are cleaned up according to your recorder settings.
