Do I need to flash new firmware to use the Sonoff 3.0 USB Dongle Plus-E for Zigbee?
I just got the 3.0 USB Dongle Plus-E dongle and have followed this guide https://www.youtube.com/watch?v=fzoiT0mUdkg but after doing that I end up with error logs in Zigbee2MQTT
[20:05:45] INFO: Preparing to start…
[20:05:47] INFO: Socat not enabled
[20:05:53] INFO: Starting Zigbee2MQTT…
Zigbee2MQTT:info 2023-08-19 20:06:08: Logging to console and directory: ‘/config/zigbee2mqtt/log/2023-08-19.20-06-08’ filename: log.txt
Zigbee2MQTT:info 2023-08-19 20:06:08: Starting Zigbee2MQTT version 1.32.2 (commit #unknown)
Zigbee2MQTT:info 2023-08-19 20:06:08: Starting zigbee-herdsman (0.17.2)
Zigbee2MQTT:error 2023-08-19 20:06:29: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-08-19 20:06:29: Failed to start zigbee
Zigbee2MQTT:error 2023-08-19 20:06:29: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
Zigbee2MQTT:error 2023-08-19 20:06:29: Exiting…
Zigbee2MQTT:error 2023-08-19 20:06:30: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:103:27)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
at Zigbee.start (/app/lib/zigbee.ts:59:27)
at Controller.start (/app/lib/controller.ts:101:27)
at start (/app/index.js:107:5)
I am pretty sure my port is set correctly with
Since I see this in the hardware settings on my Raspberry Pi 3
add
adapter: ezsp
to serial
Thank you
igbee2MQTT:info 2023-08-20 10:21:59: Connecting to MQTT server at mqtt://192.168.0.34:1883
Zigbee2MQTT:info 2023-08-20 10:22:01: Connected to MQTT server
Zigbee2MQTT:info 2023-08-20 10:22:01: MQTT publish: topic ‘zigbee2mqtt/bridge/state’, payload ‘{“state”:“online”}’
Zigbee2MQTT:info 2023-08-20 10:22:01: Started frontend on port 0.0.0.0:8099
Zigbee2MQTT:info 2023-08-20 10:22:01: Zigbee2MQTT started!
