I have 4 standard z wave switches and 3 insteon switches. I can turn the switches on and off in the HA UI and they work but I noticed yesterday if I manually toggle the switch then their status is not updated on the HA UI.
I heard from someone that since my switches are not z wave plus they need to be polled but in reading the docs it looks like polling happens every 60 seconds by default.
How do I get the HA UI to display the current status?
I only have experience with Z-Wave devices, not insteon, so I can only speak to Z-Wave…
It really depends on the switch. In my particular case I only need to do this with a couple switches. If you find you need to poll one or more devices, add polling_interval to your zwave configuration to set the basic polling interval, and then add polling_intensity for each device that needs to be polled. This second parameter basically means how often to poll it - e.g., 1 means every time its turn comes up in the polling sequence, 2 means every other time, etc.
From what I understand, the answer isn’t straightforward. It does have something to do with the licensing issues. However, even my older GE switches that aren’t Z-Wave Plus and don’t have the necessary feature are still somehow instantly updated in HA. (Someone explained it once, but I don’t remember the details. Bottom line is whether or not you see instant updates, no matter the details behind the scene.)
E.g., in my case (all GE/Jasco switches), the only ones I need polling for are the ones with Add-On switches connected to form 3-way or 4-way configurations. If the switch itself is manually operated, HA gets updated instantly. But if the switch is changed by manually operating the Add-On switch, HA doesn’t get instantly updated. This is why I use polling just with the two switches to which I have Add-On switches connected.
Insteon_plm does not require polling because all Insteon devices send status updates on state change. Per the other thread, I believe yours is a linking issue.
