Do I need two automations
I want to turn a light on with movement and keep it on until no movement is detected for xx minutes
This is off the HA cookbook site
Do I need one automation for the “Turn on kitchen light when there is movement” part and a second one for the “Turn off kitchen light 10 minutes after last movement”
When I see two aliases in one code, is that a giveaway to me that I need two?
automation:
- alias: Turn on kitchen light when there is movement
    platform: state
    entity_id: sensor.motion_sensor
    to: 'on'
    service: light.turn_on
    entity_id: light.kitchen_light
- alias: Turn off kitchen light 10 minutes after last movement
    platform: state
    to: 'off'
    for:
      minutes: 10
    service: light.turn_off
Many of the cookbook entries are quite old. These days I recommend having the “off” as a wait for trigger in your first automation action.
Yes that is two automations.
Simplest combination of the two automations:
- alias: 'Motion controlled kitchen light'
  - platform: state
    to: 'on'
  - platform: state
    to: 'off'
    for:
      minutes: 10
  - service: 'light.turn_{{ trigger.to_state.state }}'
Thanks everyone.
@123 … Very elegant solution… I am replacing all my existing automations with this
I like this a lot, very succinct. If someone needs to do a more complicated action, multiple actions, not use a template, etc… I recommend the wait_for_trigger. I only re-iterate because I feel like this newish feature is not well known!
As a refinement, you may want to add the following condition to the automation:
  condition: >
    {{ (trigger.to_state.state == 'on' and is_state('light.kitchen', 'off')) or
       (trigger.to_state.state == 'off' and is_state('light.kitchen', 'on')) }}
Basically, it prevents turning on the light if the light is already on (and turning it off if it is already off). This prevents sending needless commands to the light.
so, how would I control multiple devices?
This doesn’t throw an error but wont work
alias: Office Lights
description: ''
  - platform: state
    entity_id: binary_sensor.office_motion
    to: 'on'
  - platform: state
    to: 'off'
    for:
      minutes:10
    entity_id: switch.office
    entity_id: light.office_accent
Yes, like that or you can do this:
  - service: 'homeassistant.turn_{{ trigger.to_state.state }}'
    entity_id: switch.office, light.office_accent
or like this:
    entity_id:
      - switch.office
      - light.office_accent
The reason it calls homeassistant.turn_on (or turn_off) is because the entities aren’t all the same domain but a combination of light and switch domains.
