I used a sonoff bridge for a few years now with a bunch of door/window/water sensors scattered around my house. I actually had a second sonoff so I decided to set up a redundant bridge setup since if I happen to get two triggers of window open or door open or water sensor triggered it’s not a big deal. It worked great, HOWEVER, about two or three months ago one of my sonoff bridges died so I ordered two new ones (the new ones are white and the old ones were black).
I flashed one of them with tasmota and replaced the busted one. Then suddenly I started getting a bunch of battery low signals on doors sensors that I had just replaced. I verified that the batteries had over 1.5V on them. When I look at the logs from my two tasmota consoles, I can see discrepancies!!
for example:
From old device:
12:47:06.917 MQT: tele/sonoff-bridge-a/RESULT = {"Time":"2022-09-30T12:47:06","RfReceived":{"Sync":14150,"Low":500,"High":1370,"Data":"30060A","RfKey":"None"}}
12:48:07.877 MQT: tele/sonoff-bridge-a/RESULT = {"Time":"2022-09-30T12:48:07","RfReceived":{"Sync":14140,"Low":500,"High":1370,"Data":"30060E","RfKey":"None"}}
17:00:54.535 MQT: tele/sonoff-bridge-a/RESULT = {"Time":"2022-09-30T17:00:54","RfReceived":{"Sync":14090,"Low":480,"High":1400,"Data":"5F2B0A","RfKey":"None"}}
17:00:59.258 MQT: tele/sonoff-bridge-a/RESULT = {"Time":"2022-09-30T17:00:59","RfReceived":{"Sync":14120,"Low":490,"High":1390,"Data":"5F2B0E","RfKey":"None"}}
19:33:49.525 MQT: tele/sonoff-bridge-a/RESULT = {"Time":"2022-09-30T19:33:49","RfReceived":{"Sync":14200,"Low":480,"High":1380,"Data":"332D0E","RfKey":"None"}}
19:47:16.243 MQT: tele/sonoff-bridge-a/RESULT = {"Time":"2022-09-30T19:47:16","RfReceived":{"Sync":14060,"Low":510,"High":1360,"Data":"30060A","RfKey":"None"}}
From new device:
12:47:07.533 MQT: tele/sonoff-bridge-b/RESULT = {"Time":"2022-09-30T12:47:07","RfReceived":{"Sync":27930,"Low":888,"High":2688,"Data":"30060A","RfKey":"None"}}
12:48:08.629 MQT: tele/sonoff-bridge-b/RESULT = {"Time":"2022-09-30T12:48:08","RfReceived":{"Sync":27930,"Low":894,"High":2686,"Data":"30060E","RfKey":"None"}}
17:00:55.022 MQT: tele/sonoff-bridge-b/RESULT = {"Time":"2022-09-30T17:00:55","RfReceived":{"Sync":26794,"Low":982,"High":2622,"Data":"572B08","RfKey":"None"}}
17:00:59.823 MQT: tele/sonoff-bridge-b/RESULT = {"Time":"2022-09-30T17:00:59","RfReceived":{"Sync":26268,"Low":952,"High":2650,"Data":"5F2B06","RfKey":"None"}}
19:33:50.923 MQT: tele/sonoff-bridge-b/RESULT = {"Time":"2022-09-30T19:33:50","RfReceived":{"Sync":26270,"Low":914,"High":2666,"Data":"33250A","RfKey":"None"}}
19:47:17.094 MQT: tele/sonoff-bridge-b/RESULT = {"Time":"2022-09-30T19:47:17","RfReceived":{"Sync":26104,"Low":894,"High":2688,"Data":"30060A","RfKey":"None"}}
You can see that one of them get 572B08 and 572B06 instead of 5F2B0A and 5F2B0E!! Also, the new one shows 33250A instead of 332D0E! Incidentally, the new one is closer to the sensor that it is having problems with. I think these new white ones must not work as well… and be aware of incorrect results being passed in if you happen to get a second sonoff bridge for redundancy.
If I can find the second one I bought, I’m going to program it and see if it’s any better at detecting the signals or if it sucks too…
