Do Tapo Matter Smart Switches Require Cloud Account For LOCAL ONLY Operation?
Trying to understand / figure out if TP-Link Tapo Matter smart switches can be used LOCAL ONLY without a TP-Link cloud account and without access to the Internet.
Have read the TP-Link Smart Home / Home Assistant Integration webpage ( TP-Link Smart Home - Home Assistant )
I find the following statements unclear / confusing.
“Since these devices use the same TP-Link Cloud Account for authorization, they work with this integration as well. If your device is a newer Kasa or Tapo device it will require your TP-Link cloud username and password to authenticate for local access.”
Compared to the following statement:
“The integration connects locally to the devices without going via the TP-Link cloud.”
Making things more confusing while adding a Tapo Matter switch to Home Assistant I was asked for my TP-Link Cloud user name and password. Why ask for user name and password if this was controlled local only?
Can someone provide clarification on this.
I believe that once you have registered the account through tapo then it works locally without the cloud?
not sure how that works with automations
I just added mine to HA by scanning the QR code with the HA companion. No Tapo app was required. Try resetting the device(s) and try again w/o getting the TP-Link app involved.
Hello. Which device did you add and where was the QR code? So far the only why I can add the device is first using the Tapo app.
Hi Andy.
So far the only success I have had is first setting up devices with the Tapo app, updating device firmware and then deleting device from Tapo app. After all of that I use the HA companion app to setup the device in HA and then block the device, at the firewall, from access to the Internet.
QR code is on the bulb and on an included sticker.
I have 3 (soon to be 4) Tapo S505 light switches. All where added with the matter code in the HA companion app. No account login required. I will note I had to add each of them twice, as the first time failed to complete but the second time completed. So far no issues (dropouts or otherwise) in the 6 months I have owned a Tapo light switch.
