Do we still need hassio: in configuration.yaml?
Please dont hurt me, but in the ever lasting cleaning job of the config, I suddenly realize still having
hassio:
in my Home Assistant OS configuration.yaml…
Don’t check the file every day :blush:
do we even need that still, the integration has gone from the integrations list. I am not using the default_config: configuration option, so have all integrations I need explicitly listed…
thanks for all kind reprimands…
I don’t have this in my config and everything works fine, but I’m running container xD. hassio: is not part of default_config as far as I know.
Just try it? :stuck_out_tongue_winking_eye:
yeah, did that, and all seems well…
still, wondering why the Supervisor menu points to /hassio/system/
Hassio seems to be setup:
2020-09-08 15:34:13 INFO (MainThread) [homeassistant.setup] Setting up hassio
2020-09-08 15:34:13 INFO (MainThread) [homeassistant.setup] Setting up auth
2020-09-08 15:34:13 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds
2020-09-08 15:34:13 INFO (MainThread) [homeassistant.setup] Setting up config
2020-09-08 15:34:13 INFO (MainThread) [homeassistant.setup] Setting up alexa
2020-09-08 15:34:13 INFO (MainThread) [homeassistant.setup] Setup of domain alexa took 0.0 seconds
2020-09-08 15:34:13 INFO (MainThread) [homeassistant.setup] Setting up api
2020-09-08 15:34:13 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.2 seconds
2020-09-08 15:34:13 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds
2020-09-08 15:34:13 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.1 seconds
2020-09-08 15:34:13 INFO (MainThread) [homeassistant.setup] Setting up search
2020-09-08 15:34:13 INFO (MainThread) [homeassistant.setup] Setup of domain search took 0.0 seconds
2020-09-08 15:34:13 INFO (MainThread) [homeassistant.setup] Setting up cloud
2020-09-08 15:34:13 INFO (MainThread) [homeassistant.setup] Setup of domain person took 0.5 seconds
2020-09-08 15:34:13 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2020-09-08 15:34:13 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.0 seconds
2020-09-08 15:34:13 INFO (MainThread) [homeassistant.setup] Setting up frontend
2020-09-08 15:34:13 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds
2020-09-08 15:34:13 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 0.5 seconds
and this has been there since forever:
2020-09-08 15:37:20 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /discovery request
2020-09-08 15:37:20 ERROR (MainThread) [homeassistant.components.hassio.discovery] Can't read discover info:
and never have I received a response on the issue report
All still well after removing hassio: from configuration.yaml? I’m finally getting around to cleaning up my own configuration.yaml?
It seems like this should be documented somewhere, but it’s a hard term to search for.
For anyone else wondering, I’ve removed hassio: rom configuration.yaml with no apparent effect. All working fine for weeks now.
