Do you have a working ESPhome config for Shelly 3gen 2PM?
I feel like I’m going insane while looking for an answer, which will probably be super simple.
I bought a couple of Shelly gen3 2PM relays and successfully flashed them with ESPhome. The problem is, there seems to be not a single working config file anywhere on the internet.
As all gen3 devices from Shelly, it’s running a esp-shelly-c38f chip, which apparently is pretty much the same thing as esp32-c3 (but with more memory).
When I flashed the initial sketch, I let ESPhome builder figure it out, which it did.
It gave me a esp32 header like this:
esp32:
  board: esp32-c3-devkitm-1
  framework:
    type: Arduino
Now, the sketch works, ESPhome is happy and connected, but where are all the darn GPIO connections? Where is the i2c bus? The relays?
I have the older Shelly 2PM, but that used a different processor - meaning the original config file does not work.
If you have a working one, could you please share it here with everyone?
You could start with this, try to find the right gpios from other forums if here doesn’t match.
I don’t have one working but I found some clues that might help you. The esphome devices page have the working code for a Shelly 1PM gen3 which is a start. And the Tasmota guys reverse engineered the 2PM gen3 and posted the template format, so you’d have to figured out what all those numbers map to in order to convert it to esphome code.
EDIT: ok that’s a lot of work converting the Tasmota template so, since I have a esp32-c3 tasmota device handy, I plugged in the template and here are the values which hopefully helps:
So tasmota has I2C and esphome uart connection on IO6/7?
Yes, the template implies that 2PM uses a different energy monitoring chip (ADE7953) with I2C instead of BL0952 with UART on the 1PM. Comparing the other pins with 1PM, they are almost all different except for the relay and switch (binary_sensor) 2. Again, I don’t have this module but at least one person on the Tasmota thread says it is working.
Makes sense!
Alright, I think I got it working, properly. All thanks to @peterxian and his screenshot from Tasmota. Honestly, I wouldn’t have been able to decode the Tasmota template format into anything usable. This one screenshot saved my a**, so a big thank you!
The final config file will be at the bottom, but there are some things I’m not quite sure about.
First of all, the energy monitoring chip is really ADE7953, meaning I took the ESPhome config from there.
The one thing bothering me a bit is the Use with Shelly 2.5 section of the article, where it states a GPIO16 must be used in order for the device not to overheat. I know, this is not a Shelly 2.5, but I tried anyway. I was given an error, stating that GPIO16 cannot be used, due to its conflicting function. Probably a different ESP chip so … no harm done?
The other thing I’m worried about is the adc platform for the temperature reading as the compiler says it’s deprecated. See threads here and here. Neither of those, however, make any contributions to how to solve the issue. As long as it compiles, I’ll leave it there, but if you have a solution, I’m all ears.
So anyway, here’s the final config file as well as the HA screenshot.
All sensors, relays and switches behave as expected. Hope this helps someone in the future, or can be included in the ESPhome documentation.
esphome:
  friendly_name: 1P Jídelna Vypínač 2
esp32:
  flash_size: 8MB
  framework:
    type: esp-idf
    version: recommended
    sdkconfig_options:
      COMPILER_OPTIMIZATION_SIZE: y
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxxxxxxxxxxxxx"
ota:
  - platform: esphome
    password: "xxxxxxxxxxxxx"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "1P-Jidelna-Vypinac-2"
    password: "xxxxxxxxxxx"
captive_portal:
i2c:
  sda: GPIO6
  scl: GPIO7
  - platform: ade7953_i2c
    irq_pin: GPIO1
    voltage:
      icon: mdi:alpha-v-circle-outline
      device_class: voltage
    frequency:
      accuracy_decimals: 2
      icon: mdi:cosine-wave
      device_class: frequency
    current_a:
      icon: mdi:alpha-a-circle-outline
      device_class: current
    current_b:
    active_power_a:
      icon: mdi:power
      device_class: power
      filters:
        - multiply: -1
    active_power_b:
      icon: mdi:power
      device_class: power
      filters:
        - multiply: -1
    update_interval: 5s
  # NTC Temperature
  - platform: ntc
    sensor: temp_resistance_reading
    calibration:
      b_constant: 3350
      reference_resistance: 10kOhm
      reference_temperature: 298.15K
  - platform: resistance
    sensor: temp_analog_reading
    configuration: DOWNSTREAM
    resistor: 32kOhm
  - platform: adc
    pin: 4
status_led:
  pin:
    number: 2
    inverted: true
output:
  - platform: gpio
    pin: 5
  - platform: gpio
    pin: 3
switch:
  - platform: output
    output: "relay_output1"
  - platform: output
    output: "relay_output2"
binary_sensor:
  - platform: gpio
    pin: 18
    filters:
      - delayed_on_off: 50ms
  - platform: gpio
    pin: 10
    filters:
  - platform: gpio
    pin:
      number: 19
      inverted: yes
      mode:
        input: true
        pullup: true
EDIT: Updated the pins to match properly. Device output and switch #1 correspond with values 1/A and #2 with 2/B.
And thanks to you, @Karosm. I did start with the 1PM as a base. I do have another gen3 mini after all so it should’ve been obvious to start from this position.
You’re welcome.
I add a link here for others swimming in these waters. If you fluently read scripts, these might give some useful information.
Your temperature parameters seem to be off a bit. At least Shelly 2pm gen3 supported? · arendst/Tasmota · Discussion #22526 · GitHub recommends 10 kOhm, 10kOhm and 4000.
That gives me more realistic readings, closer to 50℃ rather than 20℃.
Esphome wont compile it anymore for some time. I dont realy know how to solve this. Do you encouter the same problem? I have added the compiler output.
INFO ESPHome 2025.5.2
INFO Reading configuration /config/esphome/test.yaml...
WARNING GPIO2 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Generating C++ source...
INFO Updating https://github.com/espressif/[email protected]
  File "/usr/local/bin/esphome", line 10, in <module>
    sys.exit(main())
  File "/esphome/esphome/__main__.py", line 1083, in main
    return run_esphome(sys.argv)
  File "/esphome/esphome/__main__.py", line 1070, in run_esphome
    rc = POST_CONFIG_ACTIONS[args.command](args, config)
  File "/esphome/esphome/__main__.py", line 462, in command_compile
    exit_code = write_cpp(config)
  File "/esphome/esphome/__main__.py", line 214, in write_cpp
    return write_cpp_file()
  File "/esphome/esphome/__main__.py", line 232, in write_cpp_file
    writer.write_cpp(code_s)
  File "/esphome/esphome/writer.py", line 339, in write_cpp
    copy_src_tree()
  File "/esphome/esphome/writer.py", line 305, in copy_src_tree
    copy_files()
  File "/esphome/esphome/components/esp32/__init__.py", line 869, in copy_files
    repo_dir, _ = git.clone_or_update(
  File "/esphome/esphome/git.py", line 103, in clone_or_update
    run_git_command(cmd, str(repo_dir))
  File "/esphome/esphome/git.py", line 32, in run_git_command
    raise cv.Invalid(err_str)
voluptuous.error.Invalid: fatal: bad object refs/remotes/origin/HEAD
error: https://github.com/espressif/esp-protocols.git did not send all necessary objects
This sounds like corrupted git repo. Probably best to delete it and reclone.
Could you please share your approach to flashing the firmware? Did you manage to do it OTA or via tiny soldered pins or…?
I just plugged tiny pins into shelly and flashed it that way. Pitch changer (e.g. this one) 1.27mm to 2.54mm is helpful. It allows you to convert tiny pins you have on shelly to standard pins you find on serial adapters.
Flashing shelly 3rd gen mini is much harder though, since it only has flat contacts, so you need to solder your pins or get somebody to help you hold the wires (but even with the help it is tricky).
I flashed my Shelly 2PM Gen3 (bought June 2025) via the pins. Don’t forget to connect GPIO0 to GND. The PCB version is v0.1.3 and contains “B2445” which is also printed on the case. Attached PCB pictures for reference. As it’s the ESP32-Shelly it could be possible to flash it with GitHub - tasmota/mgos32-to-tasmota32: ESP32 Mongoose OS to Tasmota32 OTA updates for Shelly over the air.
The temperature sensor doesn’t seem to work for me, the temperature value doesn’t change.
Did you figure this out? I am looking to buy 6 2pm but I’d rather not stick them into my walls if I can’t get them to switch off automatically if it gets too hot.
I’ve been using this config successfully.
The only issue now is this strapping pin message.
GPIO2 is used for the led
status_led:
  pin:
    number: 2
    inverted: true
which leads to
Does anybody know if this is something to be concerned about?
Is your onboard status LED working as configured? If yes, all is well. The warning message is a heads up for avid tinkerers that are running out of available pins usually. Annoying, and I wish I could turn it off globally with a configuration change rather than added yaml code to suppress it. I’m not used to being treated like an idiot constantly.
Did your temperatire sensor work correctly?
I am hesitant to say it is working perfectly, but I am happy to say it’s working reasonably well. I can’t be sure that the values aren’t a tad bit too high, but they are in a range I’d expect them to be. It’s hard to know the esps temperature, but it’s generally above room temp plus a few degrees. Thanks!
