I have moved from a pi to docker. Everything is working well except I am unable to use USB to serial adapters (using win docker)
Does anyone know how to setup some Serial to Ethernet adaptors in docker?
I am not an expert and I can’t work out how to get ser2net working.
Does anyone have a guide (cant find one) or know how I can install and config this component in a hass docker image?
tmjpugh
(Tmjpugh)
2
Look into --devices call for docker
Enabling rs232 dongle should require same as enable zwave. Just define device when build container. I have not tested rs232 however
This feature doesn’t work with Windows docker
I am using Windows server 2019 which had docker native but this still does not work
tmjpugh
(Tmjpugh)
4
Yeah…I wasnt sure about that. Sorry. I thought you were asking re USB>>serial>>Ethernet not Ethernet>>serial
I think even this case you require --devices since Windows views these device as port and not network
Maybe easier to use separate device for rs232, like your RasPi, and connect via mqtt
I
