I recently switched over to Home Assistant OS from a Docker container. I installed Portainer and am trying to run some Docker Compose files, but I keep running into an error message that’s saying it’s a read only file system where I’m trying to map my bind mounts. I’ve tried putting them in several places, under /data, /config, and /addons, all with the same error message. I’ve also tried chmod’ing the directory for the bind mount to 777 with no luck.
My question is, is this expected behavior, or am I doing something wrong? I know that a lot of the Home Assistant OS is read only, but I thought directories like /data and /config were writeable. Do I need to chown the directory to the user Portainer runs as? Also if there is some other way to install docker-compose, I’d be fine not using Portainer.
I’ve tried Googling this quite a bit, but most of the results I find have to do with running HA itself in a container. I did see one suggestion to just use Docker volumes, but I’d prefer to have a persistent directory mapped to the host. Any help pointing me in the right direction would be greatly appreciated.
Thanks!
