I am using HA with host network mode and Jellyfin with bridge network mode with the appropriate ports forwarded in the docker compose file. It’s all running on an Ubuntu server 22.04 with docker installed according to the installation guide on docker.com. I wanted to setup webhooks, so I added one in HA and put the webhook address (same IP that I can use to access HA/Jellyfin) into the jellyfin plugin settings and made it working. But then I realized that Jellyfin is in bridge mode, so it’s not supposed to be able to connect to the host machine.
I was trying to find it in the documentation/google, the closest I got was docker.host.internal, but I don’t have that added in my docker compose file. I’m using the linuxserver.io image for jellyfin, don’t know if that matters.
Could someone clear this up for me?
