I’m struggling regarding usage of bluetooth in Docker-compose.
First: I have Home assistant working nicely as well as traeffik for external access to it.
Then i wanted to install my Asus bluetooth dongle on the Pi. It worked. I looked around to see if can have access to bluetooth through docker compose for HA to have a presence detection… And the results i found was to use network-mode: Host on the compose file for HA.
But now, i can’t have access to HA when i’m not in the same network…
Do you know if there is a solution for mapping bluetooth through the container and disable network-mode host as i want to have access through traefik to my instance ?
I tried this solution, and indeed, it works perfectly.
The thing is that in network mode: Host, traefik doesn’t see the Home assistant docker anymore.
One solution that i have tried is to create a python script and update via mqtt a presence sensor. It worked smoothly, but i want to know if it is not better to create the same python script and run it inside a docker container.
The fact is that Ble component on Hass.io is not very effective and i have one time or another a problem with the ble component which cause Home assistant to put me “not_home” even if i’m still at home…
Nevertheless, i am now capable of accessing Hass.io through traefik in a docker container
