Today I installed home assistant as docker on my banana pi but the config files are not showing up in the destination directory I am giving him as argument. The command was: docker run -d --name="homeass" --privileged --restart=unless-stopped -e "TZ=Europe/Berlin" -v /home/pi/homeassistant/config --net=host homeassistant/home-assistant:stable
the directories homeassistant and config where create before and the container is starting without problems in the logs but I cant find the config files like configuration.yaml which should be saved in “/home/pi/homeassistant/config”.
Does anyone have an idea what I have to change in the command? Its no problem to create a new image since I havent done much in this one for now.
if I executed docker container inspect homeass
I can see that the output direcoty is actually set also in the config file of the docker:
"Id": "9094e7a06d234f41a9cdc17010913e9e87bce3eefdab8c14e13f6ed44c410147",
"Created": "2023-02-03T11:21:00.96540989Z",
"Path": "/init",
"Args": [],
"State": {
"Status": "running",
"Running": true,
"Paused": false,
"Restarting": false,
"OOMKilled": false,
"Dead": false,
"Pid": 2805,
"ExitCode": 0,
"Error": "",
"StartedAt": "2023-02-03T11:39:06.972601472Z",
"FinishedAt": "2023-02-03T11:35:00.448917386Z"
"Image": "sha256:a44a85612bd638627325945d65ce4b7986388ea3726b5a4a211fe0a14a251d3d",
"ResolvConfPath": "/var/lib/docker/containers/9094e7a06d234f41a9cdc17010913e9e87bce3eefdab8c14e13f6ed44c410147/resolv.conf",
"HostnamePath": "/var/lib/docker/containers/9094e7a06d234f41a9cdc17010913e9e87bce3eefdab8c14e13f6ed44c410147/hostname",
"HostsPath": "/var/lib/docker/containers/9094e7a06d234f41a9cdc17010913e9e87bce3eefdab8c14e13f6ed44c410147/hosts",
"LogPath": "/var/lib/docker/containers/9094e7a06d234f41a9cdc17010913e9e87bce3eefdab8c14e13f6ed44c410147/9094e7a06d234f41a9cdc17010913e9e87bce3eefdab8c14e13f6ed44c410147-json.log",
"Name": "/homeass",
"RestartCount": 0,
"Driver": "aufs",
"Platform": "linux",
"MountLabel": "",
"ProcessLabel": "",
"AppArmorProfile": "",
"ExecIDs": null,
"HostConfig": {
"Binds": null,
"ContainerIDFile": "",,
"LogConfig": {
"Type": "json-file",
"Config": {}
"NetworkMode": "host",
"PortBindings": {},
"RestartPolicy": {
"Name": "unless-stopped",
"MaximumRetryCount": 0
"AutoRemove": false,
"VolumeDriver": "",
"VolumesFrom": null,
"CapAdd": null,
"CapDrop": null,
"CgroupnsMode": "host",
"Dns": [],
"DnsOptions": [],
"DnsSearch": [],
"ExtraHosts": null,
"GroupAdd": null,
"IpcMode": "private",
"Cgroup": "",
"Links": null,
"OomScoreAdj": 0,
"PidMode": "",
"Privileged": true,
"PublishAllPorts": false,
"ReadonlyRootfs": false,
"SecurityOpt": [
"label=disable"
"UTSMode": "",
"UsernsMode": "",
"ShmSize": 67108864,
"Runtime": "runc",
"ConsoleSize": [
0,
0
"Isolation": "",
"CpuShares": 0,
"Memory": 0,
"NanoCpus": 0,
"CgroupParent": "",
"BlkioWeight": 0,
"BlkioWeightDevice": [],
"BlkioDeviceReadBps": null,
"BlkioDeviceWriteBps": null,
"BlkioDeviceReadIOps": null,
"BlkioDeviceWriteIOps": null,
"CpuPeriod": 0,
"CpuQuota": 0,
"CpuRealtimePeriod": 0,
"CpuRealtimeRuntime": 0,
"CpusetCpus": "",
"CpusetMems": "",
"Devices": [],
"DeviceCgroupRules": null,
"DeviceRequests": null,
"KernelMemory": 0,
"KernelMemoryTCP": 0,
"MemoryReservation": 0,
"MemorySwap": 0,
"MemorySwappiness": null,
"OomKillDisable": false,
"PidsLimit": null,
"Ulimits": null,
"CpuCount": 0,
"CpuPercent": 0,
"IOMaximumIOps": 0,
"IOMaximumBandwidth": 0,
"MaskedPaths": null,
"ReadonlyPaths": null
"GraphDriver": {
"Data": null,
"Name": "aufs"
"Mounts": [
"Type": "volume",
"Name": "f9496784c586883e1ca42736698675a224f3d11d3f4447ed5c9e0cad83c2e2cf",
"Source": "/var/lib/docker/volumes/f9496784c586883e1ca42736698675a224f3d11d3f4447ed5c9e0cad83c2e2cf/_data",
"Destination": "/home/pi/homeassistant/config",
"Driver": "local",
"Mode": "",
"RW": true,
"Propagation": ""
"Config": {
"Hostname": "bpi-fabio",
"Domainname": "",
"User": "",
"AttachStdin": false,
"AttachStdout": false,
"AttachStderr": false,
"Tty": false,
"OpenStdin": false,
"StdinOnce": false,
"Env": [
"TZ=Europe/Berlin",
"PATH=/usr/local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
"LANG=C.UTF-8",
"S6_BEHAVIOUR_IF_STAGE2_FAILS=2",
"S6_CMD_WAIT_FOR_SERVICES_MAXTIME=0",
"S6_CMD_WAIT_FOR_SERVICES=1",
"S6_SERVICES_READYTIME=50",
"WHEELS_LINKS=https://wheels.home-assistant.io/musllinux/",
"S6_SERVICES_GRACETIME=220000"
"Cmd": null,
"Image": "homeassistant/home-assistant:stable",
"Volumes": {
"/home/pi/homeassistant/config": {}
"WorkingDir": "/config",
"Entrypoint": [
"/init"
"OnBuild": null,
"Labels": {
"io.hass.arch": "armv7",
"io.hass.base.arch": "armv7",
"io.hass.base.image": "homeassistant/armv7-base:3.16",
"io.hass.base.name": "python",
"io.hass.base.version": "2022.11.0",
"io.hass.type": "core",
"io.hass.version": "2023.2.0",
"org.opencontainers.image.authors": "The Home Assistant Authors",
"org.opencontainers.image.created": "2023-02-01 18:44:18+00:00",
"org.opencontainers.image.description": "Open-source home automation platform running on Python 3",
"org.opencontainers.image.documentation": "https://www.home-assistant.io/docs/",
"org.opencontainers.image.licenses": "Apache License 2.0",
"org.opencontainers.image.source": "https://github.com/home-assistant/core",
"org.opencontainers.image.title": "Home Assistant",
"org.opencontainers.image.url": "https://www.home-assistant.io/",
"org.opencontainers.image.version": "2023.2.0"
"NetworkSettings": {
"Bridge": "",
"SandboxID": "420efbec5a07cdd4539104cd2d089d2178b038fcc611208e3b703fff0665f617",
"HairpinMode": false,
"LinkLocalIPv6Address": "",
"LinkLocalIPv6PrefixLen": 0,
"Ports": {},
"SandboxKey": "/var/run/docker/netns/default",
"SecondaryIPAddresses": null,
"SecondaryIPv6Addresses": null,
"EndpointID": "",
"Gateway": "",
"GlobalIPv6Address": "",
"GlobalIPv6PrefixLen": 0,
"IPAddress": "",
"IPPrefixLen": 0,
"IPv6Gateway": "",
"MacAddress": "",
"Networks": {
"host": {
"IPAMConfig": null,
"Links": null,
"Aliases": null,
"NetworkID": "dd4b1bf855731d67ea2eaa579f723411662ae309860995d35bf19a7e0971f74a",
"EndpointID": "9efaa9624d61d6b1b7c27b244e683124669c9082c9180fe2a239fc95c837fa91",
"Gateway": "",
"IPAddress": "",
"IPPrefixLen": 0,
"IPv6Gateway": "",
"MacAddress": "",
"DriverOpts": null
