Docker container binding to UDP/53
I’m using the Docker container and network mode host to let HA do discovery, however it seems to be trying to bind to UDP/53 on the host - which is a problem when it gets started before the pihole container.
I haven’t been able to figure out why/which config option is causing that. I do not believe I have the AdGuard addon installed. Does anyone have any ideas on how to stop it from trying to bind on UDP/53 ?
There is usually system.d process on host using 53 for local dns resolution.
