Sorry about that
Here’s the entire log
Should I expect anything in the logs past “Starting Home Assistant”?
2023-01-04 01:17:58.669 INFO (MainThread) [homeassistant.bootstrap] Config directory: /root/.homeassistant
2023-01-04 01:17:59.177 INFO (SyncWorker_0) [homeassistant.loader] Loaded homeassistant from homeassistant.components.homeassistant
2023-01-04 01:17:59.183 INFO (SyncWorker_0) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification
2023-01-04 01:17:59.208 INFO (MainThread) [homeassistant.setup] Setting up homeassistant
2023-01-04 01:17:59.213 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant took 0.0 seconds
2023-01-04 01:17:59.220 INFO (MainThread) [homeassistant.setup] Setting up persistent_notification
2023-01-04 01:17:59.222 INFO (MainThread) [homeassistant.setup] Setup of domain persistent_notification took 0.0 seconds
2023-01-04 01:17:59.258 INFO (SyncWorker_3) [homeassistant.loader] Loaded default_config from homeassistant.components.default_config
2023-01-04 01:17:59.262 INFO (SyncWorker_3) [homeassistant.loader] Loaded script from homeassistant.components.script
2023-01-04 01:17:59.265 INFO (SyncWorker_3) [homeassistant.loader] Loaded scene from homeassistant.components.scene
2023-01-04 01:17:59.266 INFO (SyncWorker_3) [homeassistant.loader] Loaded tts from homeassistant.components.tts
2023-01-04 01:17:59.267 INFO (SyncWorker_3) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
2023-01-04 01:17:59.273 INFO (SyncWorker_3) [homeassistant.loader] Loaded sun from homeassistant.components.sun
2023-01-04 01:17:59.276 INFO (SyncWorker_3) [homeassistant.loader] Loaded automation from homeassistant.components.automation
2023-01-04 01:17:59.286 INFO (SyncWorker_1) [homeassistant.loader] Loaded application_credentials from homeassistant.components.application_credentials
2023-01-04 01:17:59.291 INFO (SyncWorker_1) [homeassistant.loader] Loaded api from homeassistant.components.api
2023-01-04 01:17:59.293 INFO (SyncWorker_2) [homeassistant.loader] Loaded http from homeassistant.components.http
2023-01-04 01:17:59.295 INFO (SyncWorker_0) [homeassistant.loader] Loaded blueprint from homeassistant.components.blueprint
2023-01-04 01:17:59.296 INFO (SyncWorker_3) [homeassistant.loader] Loaded auth from homeassistant.components.auth
2023-01-04 01:17:59.305 INFO (SyncWorker_2) [homeassistant.loader] Loaded trace from homeassistant.components.trace
2023-01-04 01:17:59.311 INFO (SyncWorker_1) [homeassistant.loader] Loaded config from homeassistant.components.config
2023-01-04 01:17:59.315 INFO (SyncWorker_2) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
2023-01-04 01:17:59.319 INFO (SyncWorker_3) [homeassistant.loader] Loaded device_automation from homeassistant.components.device_automation
2023-01-04 01:17:59.321 INFO (SyncWorker_2) [homeassistant.loader] Loaded bluetooth from homeassistant.components.bluetooth
2023-01-04 01:17:59.328 INFO (SyncWorker_2) [homeassistant.loader] Loaded diagnostics from homeassistant.components.diagnostics
2023-01-04 01:17:59.331 INFO (SyncWorker_0) [homeassistant.loader] Loaded usb from homeassistant.components.usb
2023-01-04 01:17:59.336 INFO (SyncWorker_2) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud
2023-01-04 01:17:59.339 INFO (SyncWorker_3) [homeassistant.loader] Loaded file_upload from homeassistant.components.file_upload
2023-01-04 01:17:59.349 INFO (SyncWorker_0) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook
2023-01-04 01:17:59.350 INFO (SyncWorker_1) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace
2023-01-04 01:17:59.358 INFO (SyncWorker_2) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
2023-01-04 01:17:59.361 INFO (SyncWorker_3) [homeassistant.loader] Loaded counter from homeassistant.components.counter
2023-01-04 01:17:59.367 INFO (SyncWorker_1) [homeassistant.loader] Loaded analytics from homeassistant.components.analytics
2023-01-04 01:17:59.374 INFO (SyncWorker_0) [homeassistant.loader] Loaded dhcp from homeassistant.components.dhcp
2023-01-04 01:17:59.377 INFO (SyncWorker_3) [homeassistant.loader] Loaded person from homeassistant.components.person
2023-01-04 01:17:59.379 INFO (SyncWorker_0) [homeassistant.loader] Loaded energy from homeassistant.components.energy
2023-01-04 01:17:59.386 INFO (SyncWorker_1) [homeassistant.loader] Loaded history from homeassistant.components.history
2023-01-04 01:17:59.388 INFO (SyncWorker_2) [homeassistant.loader] Loaded image from homeassistant.components.image
2023-01-04 01:17:59.395 INFO (SyncWorker_3) [homeassistant.loader] Loaded repairs from homeassistant.components.repairs
2023-01-04 01:17:59.396 INFO (SyncWorker_0) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
2023-01-04 01:17:59.405 INFO (SyncWorker_1) [homeassistant.loader] Loaded search from homeassistant.components.search
2023-01-04 01:17:59.417 INFO (SyncWorker_0) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
2023-01-04 01:17:59.429 INFO (SyncWorker_2) [homeassistant.loader] Loaded hardware from homeassistant.components.hardware
2023-01-04 01:17:59.434 INFO (SyncWorker_3) [homeassistant.loader] Loaded homeassistant_alerts from homeassistant.components.homeassistant_alerts
2023-01-04 01:17:59.439 INFO (SyncWorker_1) [homeassistant.loader] Loaded input_boolean from homeassistant.components.input_boolean
2023-01-04 01:17:59.444 INFO (SyncWorker_0) [homeassistant.loader] Loaded input_button from homeassistant.components.input_button
2023-01-04 01:17:59.449 INFO (SyncWorker_2) [homeassistant.loader] Loaded input_datetime from homeassistant.components.input_datetime
2023-01-04 01:17:59.454 INFO (SyncWorker_3) [homeassistant.loader] Loaded input_number from homeassistant.components.input_number
2023-01-04 01:17:59.459 INFO (SyncWorker_1) [homeassistant.loader] Loaded input_select from homeassistant.components.input_select
2023-01-04 01:17:59.463 INFO (SyncWorker_0) [homeassistant.loader] Loaded input_text from homeassistant.components.input_text
2023-01-04 01:17:59.468 INFO (SyncWorker_2) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
2023-01-04 01:17:59.473 INFO (SyncWorker_3) [homeassistant.loader] Loaded logger from homeassistant.components.logger
2023-01-04 01:17:59.478 INFO (SyncWorker_1) [homeassistant.loader] Loaded map from homeassistant.components.map
2023-01-04 01:17:59.483 INFO (SyncWorker_0) [homeassistant.loader] Loaded media_source from homeassistant.components.media_source
2023-01-04 01:17:59.488 INFO (SyncWorker_2) [homeassistant.loader] Loaded mobile_app from homeassistant.components.mobile_app
2023-01-04 01:17:59.493 INFO (SyncWorker_3) [homeassistant.loader] Loaded tag from homeassistant.components.tag
2023-01-04 01:17:59.497 INFO (SyncWorker_1) [homeassistant.loader] Loaded my from homeassistant.components.my
2023-01-04 01:17:59.502 INFO (SyncWorker_0) [homeassistant.loader] Loaded network from homeassistant.components.network
2023-01-04 01:17:59.507 INFO (SyncWorker_2) [homeassistant.loader] Loaded schedule from homeassistant.components.schedule
2023-01-04 01:17:59.511 INFO (SyncWorker_3) [homeassistant.loader] Loaded ssdp from homeassistant.components.ssdp
2023-01-04 01:17:59.516 INFO (SyncWorker_1) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health
2023-01-04 01:17:59.521 INFO (SyncWorker_0) [homeassistant.loader] Loaded timer from homeassistant.components.timer
2023-01-04 01:17:59.526 INFO (SyncWorker_2) [homeassistant.loader] Loaded zeroconf from homeassistant.components.zeroconf
2023-01-04 01:17:59.530 INFO (SyncWorker_2) [homeassistant.loader] Loaded zone from homeassistant.components.zone
2023-01-04 01:17:59.542 INFO (MainThread) [homeassistant.bootstrap] Domains to be set up: {'input_boolean', 'cloud', 'file_upload', 'system_log', 'tag', 'usb', 'script', 'repairs', 'mobile_app', 'hardware', 'frontend', 'media_source', 'analytics', 'http', 'counter', 'websocket_api', 'ssdp', 'application_credentials', 'recorder', 'system_health', 'dhcp', 'device_automation', 'search', 'scene', 'person', 'input_datetime', 'blueprint', 'api', 'onboarding', 'timer', 'automation', 'logbook', 'input_text', 'diagnostics', 'auth', 'network', 'default_config', 'input_select', 'input_button', 'logger', 'map', 'zone', 'homeassistant_alerts', 'webhook', 'input_number', 'config', 'my', 'energy', 'history', 'image', 'tts', 'sun', 'bluetooth', 'trace', 'lovelace', 'schedule', 'zeroconf'}
2023-01-04 01:17:59.546 INFO (MainThread) [homeassistant.bootstrap] Setting up logging: {'logger', 'system_log'}
2023-01-04 01:17:59.582 INFO (MainThread) [homeassistant.setup] Setting up logger
2023-01-04 01:17:59.593 INFO (MainThread) [homeassistant.setup] Setting up system_log
2023-01-04 01:17:59.615 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds
2023-01-04 01:17:59.623 INFO (MainThread) [homeassistant.setup] Setup of domain logger took 0.0 seconds
2023-01-04 01:17:59.625 INFO (MainThread) [homeassistant.bootstrap] Setting up frontend: {'frontend'}
2023-01-04 01:17:59.661 INFO (MainThread) [homeassistant.setup] Setting up device_automation
2023-01-04 01:17:59.662 INFO (MainThread) [homeassistant.setup] Setup of domain device_automation took 0.0 seconds
2023-01-04 01:17:59.868 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2023-01-04 01:17:59.896 INFO (MainThread) [homeassistant.setup] Setting up http
2023-01-04 01:17:59.908 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds
2023-01-04 01:17:59.961 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.1 seconds
2023-01-04 01:17:59.982 INFO (MainThread) [homeassistant.setup] Setting up api
2023-01-04 01:17:59.997 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds
2023-01-04 01:18:00.000 INFO (MainThread) [homeassistant.setup] Setting up auth
2023-01-04 01:18:00.012 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds
2023-01-04 01:18:00.022 INFO (MainThread) [homeassistant.setup] Setting up config
2023-01-04 01:18:00.042 INFO (MainThread) [homeassistant.setup] Setting up diagnostics
2023-01-04 01:18:00.067 INFO (MainThread) [homeassistant.setup] Setting up repairs
2023-01-04 01:18:00.073 INFO (MainThread) [homeassistant.setup] Setup of domain repairs took 0.0 seconds
2023-01-04 01:18:00.656 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.6 seconds
2023-01-04 01:18:00.665 INFO (MainThread) [homeassistant.setup] Setup of domain diagnostics took 0.6 seconds
2023-01-04 01:18:00.698 INFO (MainThread) [homeassistant.setup] Setting up file_upload
2023-01-04 01:18:00.700 INFO (MainThread) [homeassistant.setup] Setup of domain file_upload took 0.0 seconds
2023-01-04 01:18:00.817 INFO (MainThread) [homeassistant.setup] Setting up image
2023-01-04 01:18:00.823 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2023-01-04 01:18:00.825 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds
2023-01-04 01:18:00.836 INFO (MainThread) [homeassistant.setup] Setup of domain image took 0.0 seconds
2023-01-04 01:18:00.856 INFO (SyncWorker_0) [homeassistant.loader] Loaded device_tracker from homeassistant.components.device_tracker
2023-01-04 01:18:00.857 INFO (SyncWorker_1) [homeassistant.loader] Loaded group from homeassistant.components.group
2023-01-04 01:18:04.612 INFO (MainThread) [homeassistant.setup] Setting up analytics
2023-01-04 01:18:04.772 INFO (MainThread) [homeassistant.setup] Setting up search
2023-01-04 01:18:04.773 INFO (MainThread) [homeassistant.setup] Setup of domain search took 0.0 seconds
2023-01-04 01:18:04.780 INFO (MainThread) [homeassistant.setup] Setting up person
2023-01-04 01:18:04.782 INFO (MainThread) [homeassistant.setup] Setup of domain analytics took 0.2 seconds
2023-01-04 01:18:04.796 INFO (MainThread) [homeassistant.setup] Setup of domain person took 0.0 seconds
2023-01-04 01:18:04.805 INFO (SyncWorker_2) [homeassistant.loader] Loaded hassio from homeassistant.components.hassio
2023-01-04 01:18:04.810 INFO (SyncWorker_0) [homeassistant.loader] Loaded panel_custom from homeassistant.components.panel_custom
2023-01-04 01:18:04.824 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2023-01-04 01:18:04.832 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.0 seconds
2023-01-04 01:18:04.837 INFO (MainThread) [homeassistant.setup] Setting up frontend
2023-01-04 01:18:04.863 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds
2023-01-04 01:18:04.868 INFO (MainThread) [homeassistant.bootstrap] Setting up recorder: {'recorder'}
2023-01-04 01:18:04.876 INFO (MainThread) [homeassistant.setup] Setting up recorder
2023-01-04 01:18:04.903 ERROR (MainThread) [homeassistant.components.http] Failed to create HTTP server at port 8123: [Errno 98] error while attempting to bind on address ('0.0.0.0', 8123): address in use
2023-01-04 01:18:04.910 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //root/.homeassistant/home-assistant_v2.db was shutdown cleanly
2023-01-04 01:18:04.931 INFO (MainThread) [homeassistant.components.http] Now listening on port 8123
2023-01-04 01:18:05.060 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=1 from 2023-01-03 20:33:45.188922)
2023-01-04 01:18:05.111 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.2 seconds
2023-01-04 01:18:05.117 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 1: {'websocket_api', 'ssdp', 'cloud', 'network', 'usb', 'dhcp', 'webhook', 'api', 'http', 'bluetooth', 'zeroconf'}
2023-01-04 01:18:05.150 INFO (MainThread) [homeassistant.setup] Setting up webhook
2023-01-04 01:18:05.153 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds
2023-01-04 01:18:05.175 INFO (MainThread) [homeassistant.setup] Setting up network
2023-01-04 01:18:05.182 INFO (MainThread) [homeassistant.setup] Setup of domain network took 0.0 seconds
2023-01-04 01:18:05.239 INFO (MainThread) [homeassistant.setup] Setting up usb
2023-01-04 01:18:05.243 INFO (MainThread) [homeassistant.setup] Setup of domain usb took 0.0 seconds
2023-01-04 01:18:05.542 INFO (MainThread) [homeassistant.setup] Setting up dhcp
2023-01-04 01:18:05.544 INFO (MainThread) [homeassistant.setup] Setup of domain dhcp took 0.0 seconds
2023-01-04 01:18:05.575 INFO (SyncWorker_1) [homeassistant.loader] Loaded google_assistant from homeassistant.components.google_assistant
2023-01-04 01:18:05.585 INFO (SyncWorker_3) [homeassistant.loader] Loaded alexa from homeassistant.components.alexa
2023-01-04 01:18:05.615 INFO (SyncWorker_1) [homeassistant.loader] Loaded camera from homeassistant.components.camera
2023-01-04 01:18:05.930 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2023-01-04 01:18:06.065 INFO (MainThread) [homeassistant.setup] Setting up ssdp
2023-01-04 01:18:06.079 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 0.1 seconds
2023-01-04 01:18:06.436 INFO (MainThread) [homeassistant.setup] Setting up bluetooth
2023-01-04 01:18:06.481 INFO (SyncWorker_3) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player
2023-01-04 01:18:06.490 INFO (MainThread) [homeassistant.components.zeroconf] Starting Zeroconf broadcast
2023-01-04 01:18:08.580 INFO (MainThread) [homeassistant.setup] Setting up cloud
2023-01-04 01:18:08.610 INFO (MainThread) [homeassistant.setup] Setup of domain bluetooth took 2.2 seconds
2023-01-04 01:18:08.611 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 2.5 seconds
2023-01-04 01:18:08.746 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.2 seconds
2023-01-04 01:18:08.762 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 2: {'input_boolean', 'file_upload', 'tag', 'script', 'repairs', 'mobile_app', 'hardware', 'media_source', 'analytics', 'counter', 'application_credentials', 'system_health', 'device_automation', 'search', 'scene', 'person', 'input_datetime', 'blueprint', 'onboarding', 'timer', 'automation', 'logbook', 'input_text', 'auth', 'default_config', 'input_select', 'input_button', 'map', 'sun', 'zone', 'homeassistant_alerts', 'input_number', 'config', 'my', 'energy', 'history', 'image', 'tts', 'diagnostics', 'trace', 'lovelace', 'schedule'}
2023-01-04 01:18:08.778 INFO (MainThread) [homeassistant.setup] Setting up input_boolean
2023-01-04 01:18:08.790 INFO (MainThread) [homeassistant.setup] Setting up tag
2023-01-04 01:18:08.822 INFO (MainThread) [homeassistant.setup] Setting up counter
2023-01-04 01:18:08.830 INFO (MainThread) [homeassistant.setup] Setting up scene
2023-01-04 01:18:08.832 INFO (MainThread) [homeassistant.components.scene] Setting up scene.homeassistant
2023-01-04 01:18:08.845 INFO (MainThread) [homeassistant.setup] Setting up input_datetime
2023-01-04 01:18:08.849 INFO (MainThread) [homeassistant.setup] Setting up blueprint
2023-01-04 01:18:08.850 INFO (MainThread) [homeassistant.setup] Setup of domain blueprint took 0.0 seconds
2023-01-04 01:18:08.855 INFO (MainThread) [homeassistant.setup] Setting up timer
2023-01-04 01:18:08.873 INFO (MainThread) [homeassistant.setup] Setting up input_text
2023-01-04 01:18:08.880 INFO (MainThread) [homeassistant.setup] Setting up input_select
2023-01-04 01:18:08.885 INFO (MainThread) [homeassistant.setup] Setting up input_button
2023-01-04 01:18:08.889 INFO (MainThread) [homeassistant.setup] Setting up sun
2023-01-04 01:18:08.890 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.0 seconds
2023-01-04 01:18:08.892 INFO (MainThread) [homeassistant.setup] Setting up zone
2023-01-04 01:18:08.911 INFO (MainThread) [homeassistant.setup] Setting up homeassistant_alerts
2023-01-04 01:18:08.913 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant_alerts took 0.0 seconds
2023-01-04 01:18:08.919 INFO (MainThread) [homeassistant.setup] Setting up input_number
2023-01-04 01:18:08.939 INFO (MainThread) [homeassistant.setup] Setting up history
2023-01-04 01:18:08.943 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds
2023-01-04 01:18:08.947 INFO (MainThread) [homeassistant.setup] Setting up trace
2023-01-04 01:18:08.949 INFO (MainThread) [homeassistant.setup] Setup of domain trace took 0.0 seconds
2023-01-04 01:18:08.978 INFO (MainThread) [homeassistant.setup] Setting up schedule
2023-01-04 01:18:09.060 INFO (MainThread) [homeassistant.setup] Setting up hardware
2023-01-04 01:18:09.149 INFO (MainThread) [homeassistant.setup] Setting up media_source
2023-01-04 01:18:09.190 INFO (MainThread) [homeassistant.setup] Setting up application_credentials
2023-01-04 01:18:09.198 INFO (MainThread) [homeassistant.setup] Setting up system_health
2023-01-04 01:18:09.206 INFO (MainThread) [homeassistant.setup] Setup of domain scene took 0.4 seconds
2023-01-04 01:18:09.326 INFO (MainThread) [homeassistant.setup] Setting up logbook
2023-01-04 01:18:09.342 INFO (MainThread) [homeassistant.setup] Setting up map
2023-01-04 01:18:09.344 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds
2023-01-04 01:18:09.355 INFO (MainThread) [homeassistant.setup] Setting up my
2023-01-04 01:18:09.356 INFO (MainThread) [homeassistant.setup] Setup of domain my took 0.0 seconds
2023-01-04 01:18:09.435 INFO (MainThread) [homeassistant.setup] Setup of domain tag took 0.6 seconds
2023-01-04 01:18:09.470 INFO (MainThread) [homeassistant.setup] Setting up energy
2023-01-04 01:18:09.472 INFO (MainThread) [homeassistant.setup] Setup of domain energy took 0.0 seconds
2023-01-04 01:18:09.475 INFO (MainThread) [homeassistant.setup] Setting up script
2023-01-04 01:18:09.482 INFO (MainThread) [homeassistant.setup] Setting up automation
2023-01-04 01:18:09.489 INFO (MainThread) [homeassistant.setup] Setup of domain hardware took 0.4 seconds
2023-01-04 01:18:09.517 INFO (MainThread) [homeassistant.setup] Setup of domain media_source took 0.4 seconds
2023-01-04 01:18:09.519 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.3 seconds
2023-01-04 01:18:09.529 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.2 seconds
2023-01-04 01:18:09.552 INFO (MainThread) [homeassistant.setup] Setup of domain application_credentials took 0.4 seconds
2023-01-04 01:18:09.561 INFO (SyncWorker_1) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor
2023-01-04 01:18:09.578 INFO (MainThread) [homeassistant.setup] Setup of domain counter took 0.8 seconds
2023-01-04 01:18:09.604 INFO (MainThread) [homeassistant.setup] Setup of domain timer took 0.7 seconds
2023-01-04 01:18:09.767 INFO (SyncWorker_0) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
2023-01-04 01:18:09.800 INFO (MainThread) [homeassistant.setup] Setup of domain input_boolean took 1.0 seconds
2023-01-04 01:18:09.802 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.3 seconds
2023-01-04 01:18:09.813 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.3 seconds
2023-01-04 01:18:09.843 INFO (MainThread) [homeassistant.setup] Setup of domain input_datetime took 1.0 seconds
2023-01-04 01:18:09.858 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 1.0 seconds
2023-01-04 01:18:09.871 INFO (MainThread) [homeassistant.setup] Setup of domain input_text took 1.0 seconds
2023-01-04 01:18:09.891 INFO (MainThread) [homeassistant.setup] Setting up sensor
2023-01-04 01:18:09.906 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.0 seconds
2023-01-04 01:18:09.930 INFO (SyncWorker_1) [homeassistant.loader] Loaded notify from homeassistant.components.notify
2023-01-04 01:18:09.972 INFO (MainThread) [homeassistant.setup] Setup of domain input_select took 1.1 seconds
2023-01-04 01:18:10.407 INFO (MainThread) [homeassistant.setup] Setup of domain input_button took 1.5 seconds
2023-01-04 01:18:10.429 INFO (MainThread) [homeassistant.setup] Setup of domain input_number took 1.5 seconds
2023-01-04 01:18:10.453 INFO (MainThread) [homeassistant.setup] Setup of domain schedule took 1.5 seconds
2023-01-04 01:18:10.521 INFO (MainThread) [homeassistant.setup] Setting up tts
2023-01-04 01:18:10.554 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.energy
2023-01-04 01:18:10.643 INFO (MainThread) [homeassistant.setup] Setting up mobile_app
2023-01-04 01:18:10.683 INFO (MainThread) [homeassistant.setup] Setup of domain mobile_app took 0.0 seconds
2023-01-04 01:18:10.689 INFO (MainThread) [homeassistant.setup] Setting up notify
2023-01-04 01:18:10.691 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.0 seconds
2023-01-04 01:18:10.731 INFO (MainThread) [homeassistant.components.notify] Setting up notify.mobile_app
2023-01-04 01:18:11.098 INFO (MainThread) [homeassistant.setup] Setting up default_config
2023-01-04 01:18:11.100 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.6 seconds
2023-01-04 01:18:11.113 INFO (SyncWorker_1) [homeassistant.loader] Loaded backup from homeassistant.components.backup
2023-01-04 01:18:11.154 INFO (MainThread) [homeassistant.setup] Setting up backup
2023-01-04 01:18:11.157 INFO (MainThread) [homeassistant.setup] Setup of domain backup took 0.0 seconds
2023-01-04 01:18:11.169 INFO (SyncWorker_0) [homeassistant.loader] Loaded stream from homeassistant.components.stream
2023-01-04 01:18:11.193 INFO (MainThread) [homeassistant.setup] Setting up stream
2023-01-04 01:18:11.214 INFO (MainThread) [homeassistant.setup] Setup of domain stream took 0.0 seconds
2023-01-04 01:18:11.216 INFO (MainThread) [homeassistant.setup] Setup of domain default_config took 0.1 seconds
2023-01-04 01:18:11.232 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 12.10s
2023-01-04 01:18:11.235 INFO (MainThread) [homeassistant.core] Starting Home Assistant
