Same issue reported for fresh installs…
docker run -d --name=“home-assistant” -v /opt/home-assistant:/config -v /etc/localtime:/etc/localtime:ro --net=host homeassistant/home-assistant
I can connect to 172.31.253.119:8123 and create the account but then on login I get the error:
Unable to connect to Home Assistant.
When I check the error log:
2018-10-14 07:23:51 WARNING (Recorder) [homeassistant.components.recorder.migrat
ion] Database requires upgrade. Schema version: None
Here is the console output if I run the container interactively:
[root@media1 opt]# rm -rf home-assistant/
[root@media1 opt]# docker rm home-assistant
home-assistant
[root@media1 opt]# mkdir home-assistant
[root@media1 opt]# docker run -t -i --name=“home-assistant” -v /opt/home-assistant:/config -v /etc/localtime:/etc/localtime:ro --net=host homeassistant/home-assistant
Unable to find configuration. Creating default one in /config
Config directory: /config
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.loader] Loaded auth from homeassistant.components.auth
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.loader] Loaded introduction from homeassistant.components.introduction
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.setup] Setting up introduction
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.components.introduction]
Hello, and welcome to Home Assistant!
We'll hope that we can make all your dreams come true.
Here are some resources to get started:
- Configuring Home Assistant:
https://home-assistant.io/getting-started/configuration/
- Available components:
https://home-assistant.io/components/
- Troubleshooting your configuration:
https://home-assistant.io/getting-started/troubleshooting-configuration/
- Getting help:
https://home-assistant.io/help/
This message is generated by the introduction component. You can
disable it in configuration.yaml.
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.setup] Setup of domain introduction took 0.0 seconds.
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.setup] Setting up http
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds.
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.setup] Setting up recorder
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.setup] Setting up system_log
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.setup] Setting up auth
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.setup] Setting up api
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds.
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.0 seconds.
2018-10-14 08:03:26 INFO (MainThread) [homeassistant.setup] Setting up frontend
2018-10-14 08:03:27 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.5 seconds.
2018-10-14 08:03:27 WARNING (Recorder) [homeassistant.components.recorder.migration] Database requires upgrade. Schema version: None
2018-10-14 08:03:27 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 1.4 seconds.
2018-10-14 08:03:27 INFO (MainThread) [homeassistant.setup] Setting up history
2018-10-14 08:03:27 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2018-10-14 08:03:27 INFO (MainThread) [homeassistant.loader] Loaded config from homeassistant.components.config
2018-10-14 08:03:27 INFO (MainThread) [homeassistant.loader] Loaded sun from homeassistant.components.sun
2018-10-14 08:03:27 INFO (MainThread) [homeassistant.setup] Setting up sun
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.1 seconds.
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded group from homeassistant.components.group
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setting up group
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.0 seconds.
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded discovery from homeassistant.components.discovery
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setting up discovery
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setup of domain discovery took 0.0 seconds.
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded conversation from homeassistant.components.conversation
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded updater from homeassistant.components.updater
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setting up updater
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded automation from homeassistant.components.automation
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded script from homeassistant.components.script
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded map from homeassistant.components.map
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setting up map
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds.
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded sensor.yr from homeassistant.components.sensor.yr
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setting up sensor
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded tts from homeassistant.components.tts
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded tts.google from homeassistant.components.tts.google
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.yr
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.2 seconds.
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setting up config
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setting up conversation
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setup of domain conversation took 0.0 seconds.
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setting up logbook
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setting up cloud
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.0 seconds.
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setting up automation
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setting up script
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setting up tts
2018-10-14 08:03:28 INFO (SyncWorker_14) [homeassistant.components.tts] Create cache dir /config/tts.
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded config.customize from homeassistant.components.config.customize
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded config.auth from homeassistant.components.config.auth
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded config.device_registry from homeassistant.components.config.device_registry
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded config.auth_provider_homeassistant from homeassistant.components.config.auth_provider_homeassistant
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded config.entity_registry from homeassistant.components.config.entity_registry
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded config.group from homeassistant.components.config.group
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded config.config_entries from homeassistant.components.config.config_entries
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded config.automation from homeassistant.components.config.automation
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded config.hassbian from homeassistant.components.config.hassbian
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded config.core from homeassistant.components.config.core
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.loader] Loaded config.script from homeassistant.components.config.script
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.2 seconds.
2018-10-14 08:03:28 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.1 seconds.
2018-10-14 08:03:29 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.8 seconds.
2018-10-14 08:03:29 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 3.05s
2018-10-14 08:03:29 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2018-10-14 08:03:29 INFO (MainThread) [homeassistant.core] Timer:starting
2018-10-14 08:03:39 WARNING (SyncWorker_12) [netdisco.ssdp] Found malformed XML at http : // 172.31.253.118:9080: status=ok
2018-10-14 08:03:45 INFO (MainThread) [homeassistant.components.discovery] Found new service: harmony {‘host’: ‘172.31.252.198’, ‘port’: 8088, ‘ssdp_description’: ‘http : // 172.31.252.198:8088/description’, ‘name’: ‘Harmony Hub’, ‘model_name’: ‘Harmony Hub’, ‘model_number’: None, ‘serial’: None, ‘manufacturer’: ‘Logitech’, ‘udn’: ‘’, ‘upnp_device_type’: ‘urn:myharmony-com:device:harmony:1’}
2018-10-14 08:03:45 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: homekit {‘host’: ‘172.31.255.12’, ‘port’: 80, ‘hostname’: ‘porch light.local.’, ‘properties’: {‘c#’: ‘20’, ‘ff’: ‘1’, ‘id’: ‘’, ‘md’: ‘NS-CH1XIS8’, ‘pv’: ‘1.0’, ‘s#’: ‘1’, ‘sf’: ‘0’, ‘ci’: ‘8’}, ‘name’: ‘InwallSwitch-A436E8’}
2018-10-14 08:03:45 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: homekit {‘host’: ‘172.31.255.11’, ‘port’: 80, ‘hostname’: ‘NS-CH1XIS8.local.’, ‘properties’: {‘c#’: ‘20’, ‘ff’: ‘1’, ‘id’: ‘’, ‘md’: ‘NS-CH1XIS8’, ‘pv’: ‘1.0’, ‘s#’: ‘1’, ‘sf’: ‘0’, ‘ci’: ‘8’}, ‘name’: ‘InwallSwitch-A43F2A’}
2018-10-14 08:03:45 INFO (MainThread) [homeassistant.loader] Loaded upnp from homeassistant.components.upnp
2018-10-14 08:03:45 INFO (MainThread) [homeassistant.components.discovery] Found new service: plex_mediaserver {‘name’: ‘home’, ‘host’: ‘172.31.253.119’, ‘port’: ‘32400’, ‘urlbase’: ‘https : // 172.31.253.119:32400’}
2018-10-14 08:03:45 INFO (MainThread) [homeassistant.loader] Loaded remote from homeassistant.components.remote
2018-10-14 08:03:45 INFO (MainThread) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player
2018-10-14 08:03:45 INFO (MainThread) [homeassistant.setup] Setting up remote
2018-10-14 08:03:45 INFO (MainThread) [homeassistant.setup] Setup of domain remote took 0.0 seconds.
2018-10-14 08:03:45 INFO (MainThread) [homeassistant.setup] Setting up media_player
2018-10-14 08:03:45 INFO (MainThread) [homeassistant.setup] Setup of domain media_player took 0.0 seconds.
2018-10-14 08:03:45 INFO (MainThread) [homeassistant.loader] Loaded remote.harmony from homeassistant.components.remote.harmony
2018-10-14 08:03:45 INFO (MainThread) [homeassistant.components.remote] Setting up remote.harmony
2018-10-14 08:03:45 INFO (SyncWorker_6) [homeassistant.components.remote.harmony] Loading Harmony Platform: Harmony Hub at 172.31.252.198:5222, startup activity: None
2018-10-14 08:03:45 INFO (MainThread) [homeassistant.loader] Loaded media_player.plex from homeassistant.components.media_player.plex
2018-10-14 08:03:45 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.plex
2018-10-14 08:03:45 INFO (SyncWorker_13) [homeassistant.components.media_player.plex] Discovered PLEX server: 172.31.253.119:32400
2018-10-14 08:03:46 INFO (SyncWorker_13) [homeassistant.components.media_player.plex] Discovery configuration done (no token needed)
2018-10-14 08:03:46 INFO (SyncWorker_13) [homeassistant.components.media_player.plex] Connected to: http : // 172.31.253.119:32400
2018-10-14 08:04:04 INFO (MainThread) [homeassistant.components.http.view] Serving / to 172.17.0.2 (auth: False)
2018-10-14 08:04:04 INFO (MainThread) [homeassistant.components.http.view] Serving /api/onboarding to 172.17.0.2 (auth: False)
2018-10-14 08:04:22 INFO (MainThread) [homeassistant.components.http.view] Serving /api/onboarding/users to 172.17.0.2 (auth: False)
2018-10-14 08:04:22 INFO (MainThread) [homeassistant.components.http.view] Serving / to 172.17.0.2 (auth: False)
2018-10-14 08:04:22 INFO (MainThread) [homeassistant.components.http.view] Serving /auth/authorize to 172.17.0.2 (auth: False)
2018-10-14 08:04:22 INFO (MainThread) [homeassistant.components.http.view] Serving /auth/providers to 172.17.0.2 (auth: False)
2018-10-14 08:04:22 INFO (MainThread) [homeassistant.components.http.view] Serving /auth/login_flow to 172.17.0.2 (auth: False)
2018-10-14 08:04:31 INFO (MainThread) [homeassistant.components.http.view] Serving /auth/login_flow/e853f42757664800b5b7864520ce63b1 to 172.17.0.2 (auth: False)
2018-10-14 08:04:31 INFO (MainThread) [homeassistant.components.http.view] Serving / to 172.17.0.2 (auth: False)
2018-10-14 08:04:31 INFO (MainThread) [homeassistant.components.http.view] Serving /auth/token to 172.17.0.2 (auth: False)
